2nd December 2004
Posts: 347 Sportster/Buell Model: XL w/ 1200cc conversion Sportster/Buell Year: 1986
Mounting Tires
Any special tricks for mounting tires. I would save $90 by doing myself. But How? Tubeless mag front and back. Any help would help...The new forum has a good look.
3rd December 2004
Posts: 364 Sportster/Buell Model: 883 Custom Sportster/Buell Year: 2002
The hardest part to changing ANY tire is breaking the bead loose. Since these are motorcycle tires, put it into a shop vise and compress the SIDEWALLS in. Usually, only one side will break, so then place a block of wood against the wheel on the broken side and get the other side. From there, its simply prying the old tire off and sliding on the new one with dish soap. Oh yeah, install a new valve stem.
3rd December 2004
Posts: 1,354 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2000 Other Motorcycle Model: GSXR 1100 Other Motorcycle Year: 1986
How do you balance the wheel 'at home'?
3rd December 2004
When I change mine, I'll take them to the local cycle shop and get them balanced. I guess I could balance it at home with a bubble balancer.
Doesn't someone sell a cheap balancer that is basically a horizontal rod? Then the heaviest part of the wheel rotates to the bottom. Then put weights at the top.
3rd December 2004
I could probably afford to pay for balancing. However, I am interested in finding out about the bead. Where is it exactly? how do I know it is broken?
3rd December 2004
Posts: 1,792 Sportster/Buell Model: 1200 Sport Sportster/Buell Year: 1999 Sportster/Buell Model #2: Cafe el Roadkill Sportster/Buell Year #2: 199? Other Motorcycle Model: KX520 Other Motorcycle Year: 1989
I bought a bead breaker. But you can use C clamps or even a vise. Invest in a GOOD set of tire irons and be generous with the soap.
The only tires I've balanced are the ones on the race bike. At 180 MPH, I thought it a good idea. But on my street bike (that has been to 140 MPH) I don't bother. Haven't had a shake or shimmy yet and I've done quite a few tires, both front and rear.
Try it unbalance. If it doesn't shake, your OK. If it does, take it off and have it balance.
~Crim~
My photo gallery: http://xlforum.net/photopost/showgallery.php/cat/500/ppuser/184]
3rd December 2004
Posts: 2 Sportster/Buell Model: XL883 Sportster/Buell Year: 2004
Mount the tire with the spot painted on the side wall next to the valve stem.
Get the wheel and tire dynamically balanced at a shop. It will be more accurate. It is possible to balance it yourself by placing two knife edged straight edges parallel in a elevated level plane at a width a bit wider than the wheel. Insert the axel into the wheel and lay the axel across the straight edges.
3rd December 2004
Posts: 1,216 Sportster/Buell Model: xlh883 Sportster/Buell Year: 2001
I recommend buying the long tire irons with the curve on the end, and maybe dipping the ends in tool dip if they start to mar your rims.
At school, we had a tire "stand" made of a steel drum with plastic coping around the edge. Good for getting leverage with the irons, at least on spoked wheels. I only changed mags on a Coates 220. It was a stand with a pole in the middle made for changing tires. I believe Harbor Freight sells one that is similar.
The "bead" is a thick circle of rubber that holds the edges of the tire on the wheel and seals to hold the air in.
1. Remove valve stem core.
2. Break bead on both sides of tire.
3. Pry the bead off the wheel with the irons. It helps if you put the part of the bead that is 180 degrees from the part you are prying on in the center part of the rim (the drop-center). It will make more sense once you're looking at the wheel. Start on the top bead, then do the bottom bead.
4. Lube up new tire and install in reverse of removal, with the yellow dot on the sidewall lined up with the valve stem.
5. Seat new bead by filling up tire with air (with the valve stem core still removed). The sudden rush of air will hopefully seat the bead, just make sure the bead is nice 'n lubed. If you don't have a compressor, I'm not sure this would work.
If you don't have a compressor and are still stubbornly insisting on changing your tires, there is another method of seating the bead that is kinda dangerous.
**I have NEVER done this before, but I've seen it done once. Personally, I wouldn't try it.**
Put the core back in your valve stem, spray starting fluid around the wheel into the tire carcass. Then hold a lighter near the bead. The starting fluid should pop the bead right on the wheel. Or I guess it could blow you to pieces if you use too much.
Anyway, this is just what I remember from school. I live in an apartment, so I get my tires done at the shop.
4th December 2004
Riding with Angels
Posts: 381 Sportster/Buell Model: Chrome Yellow XL883>1200C Sportster/Buell Year: 2001
Also, when mounting the new tire, be sure that the rotation arrow is pointing the right way. Motorcycle tires have direction specific treads.
Richard
2001 XL883>1200C
"Dream as if you'll live forever, live as if you'll die today"
- James Dean
5th December 2004
Posts: 2,213 Sportster/Buell Model: 883C Sportster/Buell Year: 2000
| Thread Tools |
| Display Modes |
Similar Threads
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Need new tires this year, Metzler or HD?
klamen |
Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders |
29 |
22nd February 2005 01:30 |
Tires and winter...
XLFREAK |
8 |
22nd December 2004 14:14 |
low profile tires
seajay |
1 |
8th December 2004 14:47 |
Mounting tips?
Nurple |
3 |
5th December 2004 14:53 |
which tires?
engine |
21 |
23rd November 2004 23:08 |
