The Sportster and Buell Motorcycle Forum GL Sporster
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Fix My Hog
The Dart Flyscreen
Zippers Performance
Old 27th July 2009
bigpic87 bigpic87 is offline
bigpic87 is an unknown quantity at this point
Default high speed sputtering
whenever i get on the freeway, as soon as i go 70 or faster, my bike will start sputtering and i will be jerked forwards and backwards everytime it does this.
also, my bike idles just fine, when i drop it into 1st, it shuts off. any tips or ideas for either of these problems? thanks. oh yeah, its an 82, with cycle shack slip ons.
Old 27th July 2009
Ivan RoachCoach's Avatar
Banned
Default "Cycle Shack slip ons" doesn't mean shit. What kind of carb...
...and ignition do you have on it?
Old 27th July 2009
milmat1's Avatar
milmat1 milmat1 is offline
Known Troublemaker !
Sportster/Buell Year: 06
milmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant future
Need more info, But sounds like its starving for fuel ! Maybe an Air Leak !
New to the Harley World, Some Good Info Here : NEW TO HARLEY'S
READING SPARK PLUGS: READING PLUGS
Check For Intake/Exhaust Leaks: CHECKING For Leaks
How to Check the Diaphragm! : Diaphragm_Test
REPLACING INTAKE/CARB SEALS:Replacing Intake Seals
MAINTENANCE INFO 04-06 : HANDY REFFERENCE
My futile attempt at Blogging: http://toolstolivewith.blogspot.com/
Old 27th July 2009
Banned
Default Or a clogged fuel filter, or a bad petcock. But we'll never...
...know because now he's disappeared after posting the vague question with zero details.
Lord grant me patience...
- SPORTSTER -
Kicking Big Twins in the motherf******g NUTS since 1957
CTFS/QCB
Viva Los Bastardos!!!
Old 27th July 2009
gratefulmelon's Avatar
gratefulmelon gratefulmelon is offline
gratefulmelon is an unknown quantity at this point
I have a similar problem with my 75'. Whenever I get up to highway speed and roll the throttle it starts to sputter. Its got the original carb on it and I'm thinking this might be the problem. The damn thing runs rich as hell no matter how you adjust it.
Old 28th July 2009
SilverShark96's Avatar
SilverShark96 SilverShark96 is offline
SilverShark96 is on a distinguished roadSilverShark96 is on a distinguished roadSilverShark96 is on a distinguished road
As far as I know, it shouldn't be doing that with the stock carb. You should try to mess around with the mixture screws and see if you can't fix that. If it's sputtering when you "roll the throttle" then I doubt it's running too rich. I would think it's the opposite; you're starving the engine of fuel. And if you are convinced that your mixture (idle and under load) is too rich then you should probably look to lack of fuel in the bowl.
Just my $0.02
Old 28th July 2009
I would, as already suggested, look first at the float level. For the stock carb it should be 16 or 17 mms, exactly, measured pictured in the factory manual. You may find it to be 14 or 15.
Old 28th July 2009
madfox22 madfox22 is offline
Sportster/Buell Model: XLS1000
Sportster/Buell Year: 1982
Other Motorcycle Model: BSA 650 chopper
Other Motorcycle Year: 1970
madfox22 is an unknown quantity at this point
Gratefulmelon, are you running straight drag pipes ? The inside of my exhaust always looked like the carb was running rich. I went thru that with mine. I ran the bendix carb and messed with it for a long time. Bike ran great, no sputtering, but pipes always looked black and sooty no matter what I did to the carb.
Changed pipes and it seemed to solve the problem.
Old 28th July 2009
Yeah I'm running straight drag pipes. I've tried adjusting the mixture and also rebuilt the carb...no luck.
Old 28th July 2009
Banned
Default So what happened to the original poster of the thread?...
...That's really nice --- ask a question and not even show the courtesy of responding when guys try to help you out.
- SPORTSTER -
CTFS/QCB
