The Sportster and Buell Motorcycle Forum GL Sporster
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Cafe Racer Sportster Motorcycle Talk
NHRS Performance
CV Performance
Progressive Suspension
Biltwell
Old 26th June 2007
kev2002 kev2002 is offline
Sportster/Buell Model: xlh 883
Other Motorcycle Model: Dyna wide glide
Other Motorcycle Year: 1997
kev2002 is an unknown quantity at this point
Default clip ons
Anyone have pics of their clip on's installed? i want to keep my stock speedo and want to see what you have done with the handlebar clamp.
Old 26th June 2007
streetfightster's Avatar
streetfightster streetfightster is offline
Sportster/Buell Model: stage 47 1200r
streetfightster is on a distinguished roadstreetfightster is on a distinguished road
when i had clip-ons on my bike, i just hogged out the holes on the tach mount and bolted it to my upper tripple clamps where the ugly headlight visor was mounted. no pictures though sorry
time to put away my flaked 3/4 helmet until they go back out of style.
Old 26th June 2007
Joe Dirt's Avatar
Joe Dirt Joe Dirt is offline
Joe Dirt has disabled reputation
Here's mine, like Streetfightster described.
The headlight eyebrow is mounted under the top clamp Edman style.
Old 26th June 2007
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
Looks good Joe.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
Old 27th June 2007
Thats what I want to do. How exactly did you move the gauges like that?
Old 27th June 2007
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER "black racer"
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Honda 500 Four
Other Motorcycle Year: 1973
beuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud ofbeuz has much to be proud of
That's where the original headlight visor is fixed on the top triple tree.
You just need 2 small spacers.
I did the same, many years ago before changing for wide triple tree.
You live more in 5 minutes flat out on a bike like this than most people do in a lifetime...
Burt Munro.
Old 27th June 2007
tinman3 tinman3 is offline
Sportster/Buell Model: XL 1200 conv. Stage II
Sportster/Buell Year: 1989
Other Motorcycle Model: Kaw ZRX 1200
Other Motorcycle Year: 2002
tinman3 is an unknown quantity at this point
What is Edman style?
Old 27th June 2007
jssport's Avatar
jssport jssport is offline
Sportster/Buell Model #2: 100 inch Whiplash LSR
Sportster/Buell Year #2: 91
Other Motorcycle Model: Ducati ST4s / KTM 200 EXC
jssport has disabled reputation
I grinded off part of the stock eyebrow and used a 6 in longer clutch cable (barnett). I routed it down the right side fork tube then came back over to left side under the bottom clamp.
When I tried it with the original cable the turn was too sharp and made the pull too heavy, it worked good with the longer cable on the right side.
Old 27th June 2007
Joe Dirt's Avatar
Here's a pic without the hat. You can slightly tweak the gauge bracket holes to fit, or on mine, the bracket is trimmed and new holes drilled. The headlight eyebrow is trimmed, as is the fairing bracket to fit between the clip-ons. The two same bolts mount the eyebrow and the gauges, coming up from the bottom, and thread into the top clamp.
Edman's bike has been a huge inspiration and blueprint for a lot of us, and has the lowered headlight mod, so I just connect the two.
Here's his site: www.earth2us.com/bike/cafe.htm
Google 'sportster cafe' and it's #1.
Old 28th June 2007
Thumbs up
Edman's bike rocks. I see where the insperation comes from. I think I'll have me on of these! Or sumpthin' like it.
