The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 3
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Intake and Exhaust > Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust
Licks Cycles
Ironworks Magazine
Sky Smith Insurance
CV Performance
Old 27th December 2009
hdsteve69 hdsteve69 is offline
Sportster/Buell Model: xl1200 custom
Other Motorcycle Model: heritage softail classic
hdsteve69 is an unknown quantity at this point
Default Air filter ideas
While I'm waiting for my led sled rigid frame kit to come I thought I would start figuring out what I'm goin to do with a few things on the bike,I got to lookin at the air cleaner right now it is a SE with chrome ham can cover .I would like to use the filter and mounting plate but want to change the outer cover so the filter will be open.(not worried about rain ran open before and never had a problem) A buddy of mine has cnc equipment and can do anything I need so looking for some ideals and pics of self made covers any help would be greatly appreciated.
jharback's Avatar
jharback jharback is online now
Other Motorcycle Year: 1998
If it's a good sturdy K&N filter you could just cut an inch or so off the back of the cover leaving that 1" of filter exposed. Or you could cut slots in the front and rear of the cover to allow more air flow.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
One of my thoughts was to have my buddy make a aluminum or steel plate that was the same shape as the filter itself and use the 2 screws that hold the outer cover to the filter to hold the plate .
Gone Gone is offline
I was running my SE A/C like this for awhile.
Drop the cover and make a plate that stops at the filter then bolt the logo on.
Thats what I was thinkin ,how did that work for you .I did the same thing on a fxdwg I had and used an HD filter cover insert for the outter cover which left the filter open .What did you make the outter cover out of metal or aluminum?
Worked good, used one of the wife's old baking pan's as a template, she's still wondering where it went too
I also used some small tubing pushed into the breather bolt holes and a tee fitting then drilled a small hole in the back plate to run it through to the ground to keep blowby oil from getting on the filter.
whittlebeast's Avatar
Other Motorcycle Year: 2008
It all depends if you are driven by bling or function. The big issue with most of the filter designs in the Harley world is high intake air temps. The air flow over the motor pre-heats the air for you, killing HP and promoting detonation.
Regarding engine mods, it all depends what you are driven by......
Bling, bragging rights, silky smooth power delivery, a little more peak power, violent power delivery,
traction or wheelie limited acceleration, a sound that just drips testosterone or peace of mind that
everything is as perfect as you know how to make it.
When the racers get done doing the impossible the engineers get a chance to correct the errors in the model.
***My other addiction, running Megasquirt EFI ***
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
I know you've had good experience with your tube style aircleaner versus stock, but did you ever take any heat measurements with a ham can style cover that didn't force all of the air directly from the engine in? The stock cover directs air directly from the engine, but a cut cover allows air in from other directions, particularly when moving. It might not be as efficient with heat reduction as the $500 tube, but if its a free mod and it goes in the right direction, I wouldn't call it bling.
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
see
http://xlforum.net/vbportal/forums/s...d.php?t=465835
Here it is.
On the top was Floyd's trace compared to my screaming eagle setup on the bottom.
http://www.ncs-stl.com/SertTune/IAT_Compare.jpg
