Go Back   The Sportster and Buell Motorcycle Forum > BUELL MOTORCYCLE ZONE > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
Primordial Cycles
Biltwell
Don's Cyclewear
buell, conversion, size, springer
Old 26th January 2010
Justspin's Avatar
Justspin Justspin is offline
Sportster/Buell Model: m2 cyclone
Justspin is an unknown quantity at this point
Question buell chopper
I tried searching multiple times, but it errors out on me so hopefully this hasn't been covered too many times. I'm just about finished building my Buell chopper and I'm really unsatisfied with re-using my 02 Buell M2 Cyclone front end. Bike is in storage for another month without easy access so I'm turning to you guys for some help as I'd like to start ordering parts. I need to know what the specs on the front end are (Measurements I would need to buy new springer front end) I want to add a few more inches in length. I also want to keep my stock Buell wheel, but plan on adding a bit taller tire. Any suggestions or help would be GREATLY appreciated...
Tim
snowman's Avatar
snowman snowman is offline
snowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to beholdsnowman is a splendid one to behold
Need to know what frame you are using, rake in the neck and rear wheel/tire size to get you in the ballpark...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
Justspin's Avatar
Frame is from Gypsy choppers and I bought this as an unfinished project so I don't know what the rake is and the frame neck was made to re-use the Buells front end, so I guess I'm just asking what size neck is? and would it be easy to use my Buells stock wheel and brakes on another front end? Are Buells same as certain Harleys or am I going to run into metric vs american measurements. I'm pretty sure front axle is probably metric. I hope I'm not being confusing.
garrett302's Avatar
garrett302 garrett302 is offline
Sportster/Buell Model: XL1200H
Other Motorcycle Model: SX250 Street Tracker
Other Motorcycle Year: 1976
garrett302 will become famous soon enoughgarrett302 will become famous soon enoughgarrett302 will become famous soon enoughgarrett302 will become famous soon enoughgarrett302 will become famous soon enoughgarrett302 will become famous soon enoughgarrett302 will become famous soon enough
The M2 front axle will be metric. 17mm? I can't remember, but yea, it'll be different than an HD axle.
Garrett302
NotPunkEnough(tm)
