Marks Moto Gear
Zippers Performance
Get Lowered
Ironworks Magazine
Old 22nd July 2007
el jeffe el jeffe is offline
el jeffe has disabled reputation
Default poof
Hey guys- any thoughts?
Last day or two there is a puff of smoke at the exaust when starting the engine - never did that before and it's gotten worse in one day.
Seems to run fine (?)
thanx
Old 22nd July 2007
dabronco's Avatar
dabronco dabronco is offline
Senior Master Bike Builder
Sportster/Buell Model: XLH (ironhead)
Sportster/Buell Year: '77
Other Motorcycle Model: Sold it!!
dabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura aboutdabronco has a spectacular aura about
What color is the smoke?
Murphy is my co-pilot.
Old 22nd July 2007
XLXR's Avatar
XLXR XLXR is offline
XLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to behold
Valve seal failure is common on 04's.
Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
Old 22nd July 2007
Light blue / gray color,,,seems to be oil. After initial start-up it stops smoking.
She's got near 17K miles on her. May be time for that 1200 conversion (!)
Old 23rd July 2007
Krayven Sumhead Krayven Sumhead is offline
Sportster/Buell Model: XL1200C (Heywood)
Sportster/Buell Year: '05
Other Motorcycle Model: Ultra (T-Bagger)
Other Motorcycle Year: '03
Krayven Sumhead has disabled reputation
Yup, must have the old type valve seals. The old seals allow oil to puddle around the base of the seal, when the valve opens the oil drops into the cylinder and smokes on initial cold starts. How is the oil consumption? I'm using a quart every 2,500 miles.
Old 23rd July 2007
merc merc is offline
Sportster/Buell Model: Custom
merc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud ofmerc has much to be proud of
No expert but is that common? Seems like a lot of oil use to me.
Old 23rd July 2007
Oil consuption very low...I almost never have to add oil between changes, but then again I change it often.
How hard is it to replace the seals?
