13th February 2010
Posts: 229 Sportster/Buell Model: Ironhead Sportster/Buell Year: 1965 Other Motorcycle Model: FL 1200 Panhead Other Motorcycle Year: 1956
IH - '65 - James Gasket Kit
Have just bought this Gasket kit for my '65 IH.
Even though I've been very meticulous when I disassembled the engine, I don't seem to recognize all the different gasket and seals in the kit.
Could anyone maybe give some pointer to where to put them?
Thanx,
Henrik
13th February 2010
Got a factory service manual???
13th February 2010
Posts: 899 Sportster/Buell Model: xlh Sportster/Buell Year: 78
When you buy gasket kits that span the years, they will include all the gaskets and seals for all bikes thru those years. One year might use one type of seal while yours might not need this paticular seal or that type or size gasket. So yes you will have a few that you will not use.
13th February 2010
Posts: 299 Sportster/Buell Model: XL1200N Sportster/Buell Year: 2008
I = for our white forum members
J = for our black forum members
F = for our ...
This is just wrong.. & I am just kidding!
13th February 2010
Senior Bike Builder
Posts: 1,942 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: XLC Sportster/Buell Year #2: 1958 Other Motorcycle Model: XLRTT Other Motorcycle Year: 1966
Hi Alfons,
A: Kicker shaft square seal in back of left case
B: Gear shaft seal in right case
C or D: Clutch rod seal in clutch gear or its nut depending of year
J: Probably cluch drum oil seal
E: Clutch push rod seal in sprocket nut
Some of the others are mainshaft oil seal in left case and mainshaft sprocket oil seal in right case, hard to say without dimms!!!
Patrick
Flat Head Forever...
13th February 2010
Posts: 299 Sportster/Buell Model: XLCH Sportster/Buell Year: 1968 Other Motorcycle Model: Anniversary VRod VRSCA Other Motorcycle Year: 2003
Thanx,
Henrik
A. Kicker shaft seal
B. Shifter shaft seal
C, D. Clutch push rod seal, earlier sportsters
E. Clutch push rod seal, gear side, earlier sportsters
F. Magneto seal, early sportsters
G,H,I,J various clutch hub and sprocket seals, differing years
13th February 2010
Oh that's a great help. Appreciate it.
Thanks..
| Thread Tools |
| Display Modes |
