The Sportster and Buell Motorcycle Forum Zipper's Performance
Flying Piston
Biltwell
The Dart Flyscreen
Fix My Hog
Old 22nd February 2010
weaverkb's Avatar
weaverkb weaverkb is offline
weaverkb is an unknown quantity at this point
Default Oops
So I finally got the bike (74 XLCH) mostly back together after 2 years and wanted to see if it would kick over. Bought a new battery, points
and condenser and used the old coil and mech reg. I hooked up the battery and gave it a good kick. I was amazed that it started on the first try. It ran but ran like crap. No amount of timing adjustment helped it. After I shut it down, I realized that the battery terminals were opposite of my old battery and I had it hooked up backwards. Now, I'm no electronic genius but I know that's not good for it. Now the generator is energized with the key turned off. Anyone have any idea of what this fried so I don't go throwing parts at this to fix it?
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
Most likely the reg. got fried or welded the contacts together.Plus you should always "polarize" the gen. AFTER any wires are disconnected and re-connected. Disconnect the battery, replace the reg., hook the battery up correctly, polarize the gen. Then go riding.
Old 26th February 2010
weaverkb's Avatar
Thanks man. That's one of the things I love about these old bike. Pulled the reg apart and got the contacts separated and it was good to go again.It also helped when I found that both intake valves were way loose.
dr.feltersnatch's Avatar
dr.feltersnatch dr.feltersnatch is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 08
Sportster/Buell Model #2: Xlh
Sportster/Buell Year #2: 77
dr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud ofdr.feltersnatch has much to be proud of
What kind of reg you runnin? I might have one ill give ya
"A man dies when he does not stand up for what he knows is right"
76 sporty's Avatar
76 sporty 76 sporty is offline
Sportster/Buell Model: sportster xl
Sportster/Buell Year: 1976
76 sporty is on a distinguished road76 sporty is on a distinguished road
Ok so this may be a stupid question but how do you polarize the generator
brownskull brownskull is offline
Sportster/Buell Model: Sportster 1000cc
Sportster/Buell Year: 1982
brownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enoughbrownskull will become famous soon enough
Not a stupid question..... I don't know either. Share the knowledge!
BSkull
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
The complete process is found in the Red Technical Sticky's located at the top of the Iron Head Forum's opening page.
I have copied the relevant section on "generator polarizing" here below for you.
The entire section is located here as well.
http://xlforum.net/vbportal/forums/s...d.php?t=465866
10. Polarizing the Generator - The Complete Story
Contributed by Fe Head and carmine73
1. with the gen on the bench
[i] jumper the gen A to batt +ve
[ii] momentarily jumper from gen F to batt -ve
Note: This can be done the other way around,
[i] jumper gen F to the -ve batt
[ii] momentarily jumper gen A to batt +ve
2. with the gen on the bike, wires not connected
[i] jumper from gen F to a good ground
[ii] momentarily jumper from gen A to batt +ve
Note: This technique is preferred over #3 because the good ground is better than relying on grounding the F thru the reg.
Note: As with #1 this can be done the other way around.
3. with the gen on the bike, all wires connected
[i] momentarily jumper gen A to batt +ve
Note: This is technically the same as techniques #1 and #2 as the F is grounded thru the reg.
4. For bikes with a mechanical reg [1959 to 1977]
Momentarily jumper between BAT and GEN on the reg.
Note: this is technically the same as all of the other techniques as BAT is connected to batt +ve and GEN is connected to gen A.
5. For bikes with a Cycle Electric Generator/Regulator
Contributed by FourCams
All the best as you work through the Sticky's.
Cheers;
Old 2nd March 2010
weaverkb's Avatar
I'm running the old original bosch mechanical reg. It's working fine now but I'm eventually going to step up to electronic ign and alternator.
Old 3rd March 2010
Why bother with a update, properly serviced you should get 30 years or more out of what you have
Old 3rd March 2010
weaverkb's Avatar
That's the problem, I have a tendency to not keep up with things like that. The less stuff there is to maintain, the better.
