12th March 2010
Posts: 579 Sportster/Buell Model: 1200C Sportster/Buell Year: 2004 Other Motorcycle Model: Vespa Sprint Other Motorcycle Year: 1974
1200 Stock final drive ratio
I'm ordering a chain conversion kit from zippers today and I want to know what the stock final drive for a rubbermount 1200 is. I think I want the chain as close to stock. And what if I want more ACCELERATION, do I go up with the ratio ( like 2.0 to 2.3) or down?
Thanks
12th March 2010
Brass Nut
Posts: 30,465 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2013 Sportster/Buell Model #2: XL883C … long gone Sportster/Buell Year #2: 2005 Other Motorcycle Model: FXDB … gone! Other Motorcycle Year: 2012
In the US: 68/29. Elsewhere: 68/30.
If you want more acceleration you want a smaller tranny sprocket or larger rear wheel sprocket.
Folkie
'The green machine'
12th March 2010
Posts: 351 Sportster/Buell Model: 1200 Sportster/Buell Year: 1998
Yes and if you move one tooth in the front, you might be able to use your same belt. If you change the rear, you'll need to go more teeth and will normally have to change belts = more $.
Ol' Dirty Kent of the White Werewolfes MC
12th March 2010
So, my US model has a final ratio of 2.34, correct? If I want more acceleration at the cost of low rpms at high speeds should I get a lower ratio, like 2.10?
12th March 2010
Jester Mafia
Posts: 8,595 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 Other Motorcycle Year: 2012
Backwards
2.34 is the 1200 gear
2.42 is the 883 gear
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
12th March 2010
Brass Nut
No, a higher one: smaller tranny sprocket and/or bigger rear wheel sprocket → bigger reduction.
Ie: more mechanical advantage, lower output (revs).
13th March 2010
Ok, so now I'm throughly confused. I understand the math thanks to you guys but I can't apply it.
Like I said I'm ordering from Zipper's and this is from their website:
SPORTSTER: Choose between 19-26 teeth on the transmission sprocket, 46-55 teeth on the rear (21/23 front, 46-51 rear sizes fit best on ‘91-’03 models; 2004-up models require larger diameter sprockets [25/26 front, 52-55 rear] to clear the passenger peg mounts on the frame).
http://www.zippersperformance.com/ca...=822&prod=2167
So the "biggest" ratio I can get for my rubbermount sporty is 2.2 ratio from the 25 front sprocket and a 55 rear. Thats not even close to my stock ratio and I wanted to go a bit higher then stock. Can someone inlighten me or am I still doing bad math?
13th March 2010
[SIZE="1"]So the "biggest" ratio I can get for my rubbermount sporty is 2.2 ratio from the 25 front sprocket and a 55 rear. Thats not even close to my stock ratio and I wanted to go a bit higher then stock. Can someone inlighten me or am I still doing bad math?
No the biggest would be an 18 or 19 front (smallest available) and the largest rear available. This will give you the highest (numerical) and quickest accelerating ratio. It will also produce the highest RPM in any given gear at any given speed.
edit:
I see what your talking about concerning their "recommendations". I'd talk to them on the phone and see why a smaller front sprocket on your rubber mount won't work. Also, there are companies who'll make any sprocket you ask for. If these guys can't help you check:
http://www.sprocketcenter.com/?gclid...FRUjawodqBVeUQ
http://www.pmpsprockets.com/
http://sidewindersprockets.com/
13th March 2010
Brass Nut
Do they do the smaller sizes of tranny sprocket to fit the rubber mounts?
13th March 2010
Jester Mafia
Divide the rear tooth count by the front tooth count
55 divided by 22 = 2.5
Front sprocket will turn 2.5 times for every rotation of the rear.
| Thread Tools |
| Display Modes |
