11th August 2007
Posts: 139 Sportster/Buell Model: XL1200N Sportster/Buell Year: 2008 Sportster/Buell Model #2: XLS Sportster/Buell Year #2: 1980
Originally Posted by IronMick
Spark Plug Gap:
correct gap for electronic ingition is 040
correct gap for points ignition is 030
Really I did not know this, I have had mine @ 30 with a Hi 4, I will try @ 40 and see if it makes my plugs last a little longer.
Fingerpie
Stupid risks make life worth living! - Homer Simpson
11th August 2007
Posts: 42 Sportster/Buell Model: S3T Thunderbolt Sportster/Buell Year: 1997 Sportster/Buell Model #2: P3 "BLAST" Sportster/Buell Year #2: 2000
Wal-Mart #8810 because the price is right !!!
In BUELLing
LaFayette
11th August 2007
Posts: 187 Sportster/Buell Model: SPORTSTER XLH Sportster/Buell Year: 1973
I have them all.
Bosch..... did'nt run good at all
autolite..... fouled bad first 100 miles
champion... seemed like not as much high end power
accel ugroove......... 1500 or so miles, and fouled, but could have been
cleaned. i was told accel's are made by
champion
nkg....................... ran great, brownish color after 400mile run at highway
speeds. using as spares now
harley.................... seems to run the best, both high and low end, they're
alittle darker after a couple hundred miles but, it runs
strong, starts first kick every time.
11th August 2007
Posts: 972 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974 Other Motorcycle Model: Yes
If your fouling plugs....try the next higher heat range. Course the motor may run a little hotter, but so what.
The reasons for continual fouling of plugs are numerous. Running thru the list of fixes/checks in your manual will likely solve the problem.
If you have any substantial mileage or hard use on the bike, you know its probably time to do a top end.  Hrdly
11th August 2007
Red Beard Cycles
Posts: 9,955 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997 Other Motorcycle Year: ALL
I use the NGK DCPR7E
They seem fine , actually help fix my rich condition.
I have the NGK DCPR8E on the shelf If I need to change the Heat Range.
Gapped to 40 using a wire gapper (Those slider type are for the birds)
I AM THE REAL BAT-MAN!
You Can't Fix STUPID !
Originator of the " NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
11th August 2007
Posts: 462 Sportster/Buell Model: xls 1000 Sportster/Buell Year: 1981
When I first got my bike, the front plug died. I don't remember which brand but I just looked up a cross reference for the recommended Harley plug for an '81 ironhead and bought Champion RL82YC plugs. Been running for almost 1000mi with no problems.
11th August 2007
Posts: 864 Sportster/Buell Model: XLCH Sportster/Buell Year: 1970 Other Motorcycle Model: Triumphs Other Motorcycle Year: 1964
My friend and mentor Ben, an old Dodge Mechanic... told me to run what the manufacture says to run....HUMMMM???? Harley... use Harley plugs, what a concept.. he said if it's a Ford, he runs Autolites... GM.. run Champions... Jap Car..run NKGs... he will be 78 in Jan. I listen to my elders..
BTW.. I have tried them all.. I run Champion Plugs. If the bike is set up right they do fine.. I run them in my Triumphs too...
Jim
11th August 2007
Posts: 1,691 Sportster/Buell Model: XLH Sportster/Buell Year: 1980 Other Motorcycle Model: FXDBi Street Bob Other Motorcycle Year: 2007
I am also running the Harley plugs about 700 miles so far and have had no problems yet.Like Aphico said they run a little more on the brown side than tan but run great.Next time around I will try NGK's and see how they run.
Ain't No Head Like an Ironhead !!!!!!!
Chris
http://xlforum.net/photopost/showgallery.php?cat=500&ppuser=13392 My Gallery
http://outlaws-iguana-ranch.com Outlaws Website
http://i258.photobucket.com/albums/hh266/OutlawTexan67/My%20Ironhead/Gifs/BigRotatingSkull.gif "Ironhead Mafia" European Chapter
11th August 2007
Posts: 219 Sportster/Buell Model: XLH 883 Hugger > 90" NRHS Sportster/Buell Year: 1990 Other Motorcycle Model: HD Road Glide Other Motorcycle Year: 2005
Champions are hard to beat. I'm running the HD plugs currently with no problems. I couldn't get a set of Champions at the local Auto-Zone last time I went there because I don't speak spanish very well.
There are 2 secrets to life that I live by.
1) Never tell anyone all your secrets.
2) See #1
http://xlforum.net/photopost/data/500/medium/Side1small.jpg
1990 883 Hugger converted to 90" NRHS, Buell heads w/NRHS Stage II work, S&S rods and lifters, balanced flywheel, Andrews V9 cams, Crane Roller Rockers, D&D Fat Cat pipe, HSR45 carb on Rivera manifold, SE Ignition, Crane FireBall Volt. Regulator, KONI Shocks, Stock forks with Progressive springs, Odyssey PC545 Batt. Fat Drag Bars, Black & Chrome.
13th August 2007
Posts: 15 Sportster/Buell Model: 1963 xlch Sportster/Buell Year: 1963 Sportster/Buell Model #2: Sportster Drag Bike Sportster/Buell Year #2: 1969 Other Motorcycle Model: HD Classic Other Motorcycle Year: 1995
for ironheads the Only choice for me is ac45s made by delco,thats right GM,you can buy them @ any auto store,they are dirt cheap and the way to go especially if your testing and tunning,after you get it right then put in accel yellow plugs,and yes Mick is right 30thousandths for points and 40thousandths for electronic..oh by the way when you buy the ac45s its a pack of eight for about10bucks!
| Thread Tools |
| Display Modes |
