Primordial Cycles
Old 19th March 2010
bryguy1977 bryguy1977 is offline
Sportster/Buell Model: xls sportster
Sportster/Buell Year: 1979
bryguy1977 is an unknown quantity at this point
Default 79 xls
hey fella's my bike been sittin while I have done work on it ,before starting what should I double check ,as far as oil ect ? I know its been without oil for a while cause its all over the floor,
Old 20th March 2010
I always get really nervous when starting my bike after a winter project. Too many things done and not tested with a ride.
Both oils in? Battery full charge? Nuts and bolts all final tightened? I do a walk around and actually touch each thing. One time i did a walk around and just convinced myself everything was good; lost a loose muffler support bolt.
Next i check the running lights and turn signals; then the head light and brake light. Feels good if at least all the lights work.
Then i crank the engine with the starter motor, but the plugs out. Oh good, that works. Good sign.
Before going on the road i run the bike up and down the driveway checking the clutch and brake operation. Whooo-Hooo!
Then just around the block and back home to have another walk around. Then off for a ride.
Old 20th March 2010
the cowboy way's Avatar
the cowboy way the cowboy way is offline
Sportster/Buell Model: hand built M/XL ironhead
Sportster/Buell Year: 9293
Sportster/Buell Model #2: 1976 motor in a 1987 fram
Sportster/Buell Year #2: ????
Other Motorcycle Model: 1974 XL & 2003 FXD
Other Motorcycle Year: 7403
the cowboy way has disabled reputation
make SURE
OIL's is correct level
tires are correct P S I
brakes work and correct fluid level
Forever Two Wheels
1997 AMRA National E-class Champion
Ironhead parts I have tons of em
machine shop @ home
