Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
Marks Moto Gear
CV Performance
Get Lowered
Old 20th August 2007
goglin goglin is offline
Sportster/Buell Model: XCHL-74
goglin is an unknown quantity at this point
Default foamy oil
changed oil to an 74 xlch yesterday( 20W/50), poured in 3 quarts, after warm-up checked through the filler cap and the oil was like yellow/tan porridge !! what the h...? , too much oil ? pressure was 40 psi cold, dropped to below 10 after few minutes, the bike has been standing for 16 years, ( yes i did change other fluids , flushed gas tank etc.etc) fired up after two kicks, keihin type carb..
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
Could have been condensation in the oil passages after 16 years?
AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
Urrell's Avatar
Urrell Urrell is offline
Other Motorcycle Model: Electra Glide Ultra Class
Other Motorcycle Year: 2009
Urrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of lightUrrell is a glorious beacon of light
Default My 2p
What he said.
Oil is cheaper than an engine rebuild. After all that time there is going to be corrosion, moisture and other unwanted products in there.
If it is in otherwise good condition get it hot and do another oil change and another one after a good long ride.
We need photos!!!
Urrell
Default foamy oil
thanks for the advice, did run the bike 10 minutes with 10w/40 could not get a steady oil pressure, bike has no oil filter ( never had?), planning to install on return line asap, but scared for the milkshake in oil bag....., could not load an image , restricted to 145 kb or so , my pics was 136 kb?? ( urrell, hows uk weather today, used to live in Guildford.....)
Urrell's Avatar
We had our summer in April!!! Floods in May June & July cloudy August and are waiting for an Indian Summer in September & October to get a few trips to the Yorkshire Moors & Dales and the Lake District.
Look after yourself, And that bike.
