Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Styles > Chopper & Bobber Talk
NRHS Performance Long 2
Old 4th September 2007
Antique Engine's Avatar
Antique Engine Antique Engine is offline
Sportster/Buell Model: Rigid Chopper
Other Motorcycle Model: Honda Ascot VT 500
Other Motorcycle Year: 1984
Antique Engine is on a distinguished roadAntique Engine is on a distinguished roadAntique Engine is on a distinguished roadAntique Engine is on a distinguished road
Default One week in the rigid frame bobber build
I rode it the final time 6 days ago and then pulled it apart to chop it up. You can see what it looked like then in my signature picture.
I'm using a Paughco stock stretch, 35 degree raked frame.
Here is how it sets now:
Nothing real difficult so far.
I chose to build my own fork stops rather than buy the bearing cups with built in stops. I'm stubborn and like to do things the hard way I guess.
Upper engine mount took some fiddling with the welder, no biggy.
Extending the wiring for the apes then running it inside the bars was a bit tedious.
Modifying the stock Custom speedometer mount bracket and bar clamp to use with the apes and short FX risers took a bit of head scratching.
I had to disassemble the speedometer, modify the cup, and reassemble it with the cup turned 180 degrees and flipped over. Then I had to modify the clamp so the little cluster of warning lights would be right side up again. Notice, the clamp is upside down from normal and the risers are flipped backwards too. On a stock Custom, the speedo hangs off the back of the riser and downward. Doing it this way kep the cost at zero instead of buying something else to overcome the problem.
I ran into a little hiccup in that I just had to have a spoke rear wheel, so the one I bought locally wound up being a 2000 model and my junk is a 98, so my rotor and pulley wouldn't work. Rather than modify them, I just got used off ebay and will resell my old ones to recoup costs.
I'm waiting on them to arrive so I can nail the rear wheel down permanant. I've already got the rear brake and spacers worked out, so the thinking part is done.
My oil tank and seat, and peaked rear fender are due delivery any day too.
I've built a frisco gas tank with a molded center rib and a big polished brass cap like my fire truck uses. That took a good bit of time. Bodywork is one of my weak areas. I can do it okay, it just takes me too long.
I'm hoping to have it back on the road real soon.
Paughco frames are the bomb !
Old 5th September 2007
Dlish's Avatar
Dlish Dlish is offline
Sportster/Buell Model: motorcycle
Other Motorcycle Model: Bastard mess of parts
Other Motorcycle Year: 1941
Dlish has disabled reputation
wow, serious tits right there. I really cant wait for more frame options for the rubber mounts...i really dig what your doing
"Well why don't you cry about it, saddlebags!"
Moved On Moved On is offline
Looking good!!!
Gazza
Gary, I'm sending you a PM about the dog breath.
Got it reply sent
Gazza
Gary, I appreciate the reply.
Once it's bled, I can't imagine it ever really being a concern again. I belive I'll run a brake de' Dog Breath on my junk.
hannibalmoosh hannibalmoosh is offline
Sportster/Buell Model: custom Mcworx frame
Sportster/Buell Year: 97
hannibalmoosh has disabled reputation
Looking dam good!! Ditch the speedo!! Looking forward to seeing the gas tank/oil tank. What type of seat are you planing on running?
Xlr8n's Avatar
Xlr8n Xlr8n is offline
Sportster/Buell Model: 1200 c
Xlr8n is an unknown quantity at this point
Nice stance! Keep the pics coming!
2003 1200 Custom, custom!
I ride my bike 500 miles a week. I need a speedo, there's no way I want to be rid of it. I'm also running turn signals and horn and mirrors too. They won't be gay stock looking things though.
I'm getting a British peaked rib fender and round oil tank kit from Scrapmetalart and my seat pan from Teach. Both of them are regular JJ'ers, never seen them here though.
They're both QCB'rs also, I used one of Craig's fenders and one of Teach's seats
on DogBreath. They're both excellent quality and very reasonably priced.
http://motors.search.ebay.com/_W0QQs...ontstreetcycle
http://www.baasmetalcraft.com/
Gazza
