8th June 2010
Posts: 42 Sportster/Buell Model: 883 Sportster/Buell Year: 1994 Sportster/Buell Model #2: 883 Sportster/Buell Year #2: 1996 Other Motorcycle Model: Road King Other Motorcycle Year: 2006
What Donor Bike is best?
I want a project so I've been thinking of buying a Sportster and chopping it. My Road King keeps me riding, so I don't need to jump into a purchase either. Locally I've found a 93 1200, and a 97 883. Both with approximately 20k miles with the 1200 at $3300 and 883 at $3000. Which would be a better bike to build upon and why? After the chop, I'll pump up the engines too. So does one model have better clutches, heads, forks or anything that would make it a better donor bike? Or should I just go with the less expensive?
Let me know,
Thanks,
Nickelboy
9th June 2010
Beware broken records...
Posts: 4,949 Sportster/Buell Model: XL 1200 Low Sportster/Buell Year: 2006 Sportster/Buell Model #2: 1200 XLH Sportster/Buell Year #2: 1999
I bought a '99 1200 XLH with just over 12k miles for $3300 in January. I'll bet you can get the price down with some bargaining. Personally I'd go for the '97 883 of those two. That way you can convert to a 1200/1212/1250 and keep the 883 gearing and such.
2006 1200 Low--NRHS HurricaneFlow 2", slash down Screamin' Eagle Street Performance exhaust, Progressive 12" 418s w/ heavy duty springs, Progressive fork springs + Ricor Intiminators, HD forward controls, Mustang Vintage Wide seat, HD QD windshield (smoked), HD mini-apes, and surely more to come...
1999 1200 XLH--In progress.  Custom Led Sled frame--4" up, 2" out; Baker/Vulcan chain conversion; Buell 17" rear wheel...
http://xlforum.net/vbportal/forums/s...d.php?t=708796
11th June 2010
The 883 has different gearing? In the transmission? Not just the drive pulley's?
11th June 2010
Posts: 677 Sportster/Buell Model: 883 XL converted to 1200 Sportster/Buell Year: 1994
The transmission gearing should be the same for both. The drive pulley is the only difference, 883 has 27 teeth, 1200 has 29. teeth. If you are going to run a speedo, remember that the 93 ran the speedo off the front wheel, there is no sender in the transmission like the later bike. Also the heads are different for the 883 and 1200. Some people think the chamber shape of the 883 is better, but the 883 has smaller valves. The clutches should be the same, the 93 has a different primary cover and clutch release mechanism, can't say which one is better. As far as the frame goes, the only difference I can think of is the rear fender struts. In 93 they curved down where the later bikes went straight back. Front forks should be the same. Also, if it is still stock, the 93 had a smaller gas tank, 2.5 gallon versus the 3.3 gallon for the 97. These are the only big differences that I can think of. Roger
12th June 2010
Posts: 1,033 Sportster/Buell Model: Sportster XLH1100 Sportster/Buell Year: 1986 Other Motorcycle Model: Rupp Roadster Other Motorcycle Year: 1971
In the long run, dollar for dollar the 1200 would be the better buy.
Converting the 883 to 1200 (or 1250  ) is $'s and time. Time is usually the thing most of us don't have enough of.
IMO....
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
12th June 2010
Posts: 15,359 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Yeah, I'd go with the 1200 also. Besides, everyone knows that '93 was the best year for sporty's.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
| Thread Tools |
| Display Modes |
