The Sportster and Buell Motorcycle Forum Sportster Specialty
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Lickscycles
Lickscycles
CV Performance
Old 27th June 2010
cc rider cc rider is offline
Sportster/Buell Model: 883 Hugger (NHRS 1250)
Sportster/Buell Model #2: 76 Ironhead
Other Motorcycle Model: 73 Ironhead
cc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura aboutcc rider has a spectacular aura about
Question tachometer question???
hello all, ok, i got an after market tach today. it's a drag specialties mini tach. i need to know if i need an adapter for it for a single fire ignition. i have a se ignition but don't know if it's single fire or dual fire. can anyone help me? thanks
CC
- 1997 883 Hugger with NHRS 1250 Conversion, Andrews N4 cams, stock heads, SE II slip ons, SE coil, Daytona Twin Tec 1005, Arlen Ness Big Sucker II ---1976 Ironhead stock for
now.
Old 27th June 2010
Loner's Avatar
Loner Loner is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2012
Loner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud ofLoner has much to be proud of
"usually" most SE ignition systems prior to 2004 are dual fire, with the exception of the 1998 to 2003 1200S models they came with single fire dual plug systems.
as for an adapter you might want to contact Drag and see if they got a tech dept to answer that question with the aftermarket everything is different.
Unfortunately on sporties a tach is usually not a "plug and play" situation
"I don't photograph in Black & White because I'm artistic, I'm colored blind"- unkown.
Old 28th June 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
You should have a dual fire ignition. As loner said you need to contact Drag Specialties to find out what you need. Normally you'd do this before buying.
We've all jumped on a bargain when we saw it and then regreted it later.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
Old 28th June 2010
yep you called it, i was at a swap meet yesterday and got it for a steal. but then i got home and started thinking about how to hook it up.... thanks
