Biltwell
Dead Creek Cycles
Ricor Shocks
Old 14th July 2010
Highway13 Highway13 is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Triumph
Other Motorcycle Year: 1969
Highway13 is an unknown quantity at this point
Default piston rings - stupid question
Howdy all -
I'm putting the top end of my '81 back together. My rings don't have a dot or "T" to mark the top, so I'm trying to figure out how they go in. The FSM says to put the "chamfered side up" - does that mean like this?
____
____\
and not like this?
_____
____/
Old 14th July 2010
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
Yes you are correct the chamfered side would be up as in the first illustration l_\
Old 14th July 2010
Thanks!
I felt stupid even asking, but after all the money getting it bored out and whatnot I'd hate to put 'em in upside down......
Cheers,
Blair
Old 14th July 2010
steve0suprem0 steve0suprem0 is offline
Sportster/Buell Model: XLHA the A is for AWESOME
Sportster/Buell Year: 1982
steve0suprem0 is an unknown quantity at this point
I was always told the only stupid question is the one that isn't asked. You certainly aren't gonna be judged or ridiculed from this direction. Everybody was a noob once, and some still are.
What are you talking about? Where you came from is gone, where you thought you were going to weren't never there, and where you are ain't no good unless you can can get away from it.
Old 14th July 2010
ezmerf's Avatar
ezmerf ezmerf is offline
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
You do know to ck end gap on the rings right.
Murphy's Law
Old 14th July 2010
frenchandy's Avatar
frenchandy frenchandy is offline
Other Motorcycle Model: triumph bonneville
Other Motorcycle Year: 1977
frenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of lightfrenchandy is a glorious beacon of light
tried to fit some new rings to my triumph recently.
Lucky I checked the gap as they where 2 mm!.
phoned the dealer who sent me them and he said "dont use them there s**t".
After some debate he sent me a set of decent ones free.
Rings should be marked compression ,scraper and oil by the way.
Old 14th July 2010
Yep, I checked the gap. I've just never seen rings that weren't marked, and since there's an obvious bevel on the top 2 rings, I knew one side had to be "up."
Thanks again,
Blair
Old 14th July 2010
hdsince73's Avatar
hdsince73 hdsince73 is offline
Sportster/Buell Model: xl
hdsince73 is an unknown quantity at this point
yep chamfered side up,I put them in upside down once mine werent marked either,it ran fine but smoked like a bitch because it dragged the oil up into the combustion chamber instead of down like it was suppossed to.
If you cant ride there......why even go!
