The Sportster and Buell Motorcycle Forum Sportster Specialty
Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
CV Performance
Biltwell
Ricor Shocks
Old 15th December 2004
Question Mick's Winter Project, Rear Wheel Removal
For removing the rear wheel: The book says to remove the chain connecting link. I wasgunna just loosen the alignment adjusting mechanisms as i did on my EVO. Is one of these a preferred method? Is there a special tool or technique for removing the chain connecting link? [i would prefer to avoid the flat-blade screwdriver and sore fingers routine]. Thanx in advance.
flathead45's Avatar
Sportster/Buell Year: 95
Other Motorcycle Year: 1945
flathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud of
I use a flat blade but push from the open end of the link retainer insted of trying to pry it open , if that don't work I use a needlenose plyers
"lord of the Night Lite"
thank god for darwin ;)
Old 16th December 2004
barry1967's Avatar
barry1967 barry1967 is offline
Other Motorcycle Model: 2005 FXD Chopper Blue
barry1967 is an unknown quantity at this point
BFH....
big f*#n hammer
Sorry, couldn't help it.
Stage 1
Metz 880s
V&H pipe
95 inch and more very soon.
Tried first to push the clip with the flat blade screwdriver parallel to the length of the chain to push it back off the link. No good. Then tried perpendicular, towards myself. Top half popped off then bottom half. was easy. Got the wheel etc off. Gettin it cleaned up back there.
Next i am going to remove the brake rotor and the chain sprocket from the wheel and clean things up there.
Similar Threads
First time rear wheel removal cantolina Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 9 12th April 2005 19:01
Mick's Project, Fork Side Removal IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 3 13th January 2005 03:17
Mick's Winter Project, newest pic IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 8 29th December 2004 14:48
Mick's Winter Project, crudy spoke wheel IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 6 24th December 2004 02:25
Mick's Winter Project, comment & Question IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 8 18th December 2004 04:38
