Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > EFI Sportster Motorcycle Talk (2007 and up)
Figure Machine
Speedway Instruments
Old 1st October 2007
SOLO RIDER SOLO RIDER is offline
SOLO RIDER is an unknown quantity at this point
Default Se Street Performance Baffles
Greetings All...I'm New To This Forum Thing So Bear With Me. I Just Put A Set Of Se Street Performance Slip Ons On My 07 883. They Look Good And Sound Okay But I Was Thinking Of Drilling A Few More Holes In The Baffles. Anyone Else Tried This? I Tried Pulling Out One Of The Baffles But Either They Are Tacked In Somewhere Or I Need A Bigger Hammer. Any Suggestions Would Be Greatly Appreciated. Thanks
Gone Gone is offline
A lot of people just did the "Gronk" mod or "Joe Minton" mod to their stock mufflers. Read up on the Gronk mod and see if that's what you are looking for.
Old 6th October 2007
XLFREAK XLFREAK is offline
XLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this pointXLFREAK is an unknown quantity at this point
I just removed the 2 screws holding the baffles,gripped the tail flange with some vice grips and wiggled them out...also loosen the clamp holding the slipons...drilled new holes in the same pattern and size going from 3 holes per row to 8 per row. there are 5 rows of 3 holes...now I have 5 rows of 8 holes. Much improves mileage and performance.
Old 26th July 2008
FrankBlack FrankBlack is offline
Other Motorcycle Model: Triumph Bonneville
Other Motorcycle Year: 2007
FrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really niceFrankBlack is just really nice
I was considering the possibility of this myself after buying Folkie's SPs. What was the effect on sound for you hoghead?
I'm wondering how the sound difference would compare between 1. drilling more holes of the same size; 2. drilling the existing holes bigger. I imagine one has more effect on tone and another on volume? Anyone know what effect removing the glass packing has? I'll have another look at Gronk's mod and see if I can pick anything up...
Old 26th July 2008
rfranz1952's Avatar
rfranz1952 rfranz1952 is offline
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Yamaha Vino 125
rfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nice
Make sure that any screws holding the baffles in are removed! Then, if they still don't want to slip out easily, the attached thread shows an enhancement to the vice grip method that works very well. Could save the time and trouble of pulling the slip-on and beating the baffles out with a wooden stick.
This was done on SE II's but should work equally well on any baffle that you can grip with a vise grip.
http://www.xlforum.net/vbportal/foru...748#post983748
Part of the diffculty with pulling the baffles out is it is difficult to align the force of the pull pecisely parallel to the pipe, so we are always pulling slightly to one side or the other. This will insure that the force applied is parallel to the axis of the pipe, and eliminates the alignment issue.
2005 XL 1200 Custom; NRHS 1250 Conversion, 10.5 - 1; Stage 2 Heads; SE 536 Cams; Jim's Hydrosolid lifters; NRHS adjustable pushrods; S&S Roller Rockers; Crankshaft by Darkhorse Crankworks; HurricaneFlow A/F; Hurricane Oil Filter; Mikuni HSR-42; S&S Intelligent Spark Technology Ignition; RB Racing LSR exhaust; Front and Rear Progressive Suspension; Oversize front tire; Superbrace Fork Brace; Speedway Microtach, lots of other bits and pieces.
THE $16,000 Sportster!
Old 26th July 2008
Bob F's Avatar
Bob F Bob F is offline
Hello from Pittsburgh and welcome to the forum.
Drilling the existing holes larger and adding holes will add sound and horse power. Good luck.
Old 26th July 2008
Folkie's Avatar
Folkie Folkie is online now
Brass Nut
Sportster/Buell Model #2: XL883C … long gone
Sportster/Buell Year #2: 2005
Other Motorcycle Model: FXDB … gone!
I had quite a job getting the baffles out of my Double Barrels. I took the screw out which holds the baffles in, put it inside the pipe, and use it to fix one of those 'P' shaped exhaust clamps inside the pipe. Ie: with the 'P' bit sticking out of the pipe, and facing the inside of the pipe. I then bashed away on the 'P' part of the exhaust clamp with a rubber mallet for a while, until the baffle was out. It chewed a few chunks of rubber out of the mallet, but what the heck.
Folkie
'The green machine'
Old 30th July 2008
rfranz's method works a treat. Having a lot of that unhealthy mod curiosity, I popped Folkie's SP baffles out in a jiffy the other night - no struggling at all (Folkie, you must've put some special baffle grease in there before you sold them to me, you sly devil ). Had a look around and the glass fibre packing looks like it's stuck to the insides of the cans. I imagine taking it out (to see what effect it had on sound) would mean scraping it out, and buying new fibre if you wanted it back in there. The holes in the baffles look like they could be drilled bigger in a matter of minutes though. I've decided to leave it be as these are loud enough for me right now. They tapped back in easily with a rubber mallet.
