The Sportster and Buell Motorcycle Forum Get Lowered Sportster
Lickscycles
Progressive Suspension
Zippers Performance
The Dart Flyscreen
Old 16th December 2004
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
Default Rust in the tank
Here's an good reason to winterize properly. Two years ago I laid mine up for a rebuild. I drained the tank and set it aside in preperation for painting. It was in a heated basement so I thought it wouldn't be a major concern. It was a full six months before I got it back on the road. Within weeks I was having fuel related problems. I found sediment in the float bowl several times and the needle and seat were constantly sticking and leaking. Reserve was worthless as the accumulated rust prevented proper flow. Last night I drained the tank. The strainer and the bottom of the tank was layered with gook, sludge and rust. I put in 2 quarts of CLR and did the gravel scrub.I now have it filled with CLR and soaking overnight. I'll drain and flush it tonight and hopefully be ok. It may only be a temporary fix but we'll see. I'll keep you posted.
What anyone else thinks of me is none of my business.
stevo's Avatar
stevo stevo is offline
Sportster/Buell Year: '98
stevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura aboutstevo has a spectacular aura about
ya need some tank liner POR15 is the company that makes it I think...do a search...
I know about them but I'm holding off on doing it til the weather warms. It requires a minimum of 70 degrees and 96 hours to cure. What I'm doing now is only a stop gap measure that will hopefully get me through the winter.
stevo's Avatar
OK...ya headin in the right direction then....that POR stuff is good gear I use it on all mine and make sure ALL my tanks are lined BEFORE they get airbrushed..
Could ya do the job and sit it on top of the hot water system????
hmmm, hadn't considered it. You may be onto something. I'll let you know.
stevo's Avatar
just have to ventilate well .... ya don't want that stuff in ya livin space...although the new stuff is nowhere near as nasty as the old stuff...doesn't work as well or as quick either
flathead45's Avatar
Sportster/Buell Year: 95
Other Motorcycle Year: 1945
flathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud offlathead45 has much to be proud of
not scare anyone but, I have seen some tank liner creams improperly installed that pulled loose from the inner tank and gum up everything (big mess) but that was years ago and the technology was not as good
read the directions and follow them to the letter or it will not stick properly
"lord of the Night Lite"
thank god for darwin ;)
gamhill gamhill is offline
gamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura aboutgamhill has a spectacular aura about
If it's that bad, do you really want to try and seal it? I've used the sealers before, and had mixed luck with them. You might want to just replace it. I've seen lots of tanks on eBay, I expect you could find a used in better shape.
Old 17th December 2004
It's not "that bad" yet. I think I can salvage it. I'm using the POR next week as suggested by Stevo. I've known about the stuff before but never knew anyone who used it. Stevo's recommendation is good enough for me. I do know folks that have tried the cream lining and everyone to a number says it's worthless.
I have heard several stories about the tank liners [PQR and Kreem]. One has a much better reputation than the other. Don't know which. You MUST MUST MUST follow instructions carefully exactly. I would not do it myself based on the stories i have heard. I have had two tanks lined in my past; both were done at an auto radiator shop that specializes in restoring fuel tanks. It cost about $85.00. That is 2 or 3 times what you will pay for a kit, but it is worth the extra, in my opinion, to have confidence in the job being done correctly. To locate a shop ask at any local bike shop.
Similar Threads
Found the bottom of my gas tank! gilx Sportster Motorcycle General Discussion and Problems 12 5th May 2005 19:45
Removing reflectors from fender Geek Sportster Motorcycle Custom Finishing 8 9th March 2005 01:27
Looking for a new gas tank tmcelrea Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 25 1st January 2005 23:22
Tank Expansion or Horizontal Stretch Speedy818 Sportster Motorcycle Custom Finishing 4 1st January 2005 22:39
Mick's Project, Rust in Tank IronMick Ironhead Sportster Motorcycle Talk (1957-1985) 1 30th December 2004 06:18
