Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > EFI Sportster Motorcycle Talk (2007 and up)
Figure Machine
Old 11th September 2010
modular's Avatar
modular modular is offline
Sportster/Buell Year: '12
Other Motorcycle Model: Honda 599
Other Motorcycle Year: '04
modular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to allmodular is a name known to all
Default Re-setting ECM after mods
I have switched pipes (V&H SSS to V&H Blackout). Would it make any sense to pull the maxi-fuse to re-set the ECM with the pipe switch?
Ohio Patriot Guard Rider
ElectricCityIron's Avatar
ElectricCityIron ElectricCityIron is offline
XLF Enforcer.
Sportster/Buell Model: XL 883N
Other Motorcycle Model: Kawasaki
ElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to allElectricCityIron is a name known to all
Its not really nec. The ecm in our bike willl adjust to maintain factory AF settings. If the bike did run for what ever reason excessively lean, IE leaking intake gasket then youd just pull a lean code. But swapping pipes your good.
F.T.W Molon Labe
modular's Avatar
I figured as much. Just thought I would make the learning process a little quicker by pulling the fuse. No biggie, I'll just ride it and let it learn. Not sure how much of a difference there will be between the 2 set of pipes to the ECM.
XLF Enforcer.
Theres prolly not much difference. Pulling that fuse just clears memory it doesnt do anything for ecm adjustments while driving. That will operate the same weather you pull that fuse or not. ride that biatch! lol
Bob F's Avatar
Bob F Bob F is offline
Yep, ride it like it's a rental.
