12th September 2010
Posts: 9 Sportster/Buell Model: iornhead/evo Sportster/Buell Year: 1977
help- new owner (bike only runs with choke)
Bought a 05 sportster that was rear ended from a inusrance company. Bike has bent rear rim and needs a fender. Bike will only run with choke on and barley. Pulled the plugs and man, they were not good looking. All crusty and black. Were do i start, a little concerned my good deal may not be one. Bike has 9k miles. Were do i even start? (plugs were hd plugs so prob the originals and it has screaming eagle pipes with the baffles removed)
12th September 2010
Posts: 73 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006
Put new plugs in and see what happens. The plugs are probably black from using the choke or just too rich. Stock pipes and A/C? 9K miles is prety new for that engine.
2006 1200C
12th September 2010
Okay...sorry. Need to read closer.
12th September 2010
A/C confused? There screaming eagle pipes with the baffles removed. (i didnt do it), Were would i start on it running poor or not at all with out the choke out. It wants to fall flat on its face if you give it any gas at all
12th September 2010
Posts: 15,411 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
A/C is Air Cleaner. Your plugs are black because you've been running it with the choke out. It will only run with the choke out because you are running way too lean (too much air). Sounds like you might have an air leak around the manifold. Pull your air cleaner and inspect the manifold where it is attached to both the carb and the heads.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
12th September 2010
Just ran it around the block, plugs looked real real crusty and sooted, hmmm, il have to pull the air cleaner and inspect/use some carb cleaner to see if it has leaks, any other ideas?
13th September 2010
JESTER Mafia-Hooligan Div
Posts: 9,445 Sportster/Buell Model: 1200 R Sportster/Buell Year: 2005
How long was it sitting? I'd say it also may need fresh gas.
Some use propane or WD 40 to check for intake leaks. If this has been sitting for a long time, you may want to pull the carb and give it a thorough cleaning!
Were those the new plugs that looked crusty after a trip around the block?
Stuff: YES
13th September 2010
Posts: 3,336 Sportster/Buell Model: 1200R 90+HP Sportster/Buell Year: 2004 Sportster/Buell Model #2: 2276cc VW sandrail Sportster/Buell Year #2: 1976
+1 also check the vacum operated petcock for leaks in the vacum line. I wouldn't worry too much about the running problems, this can be fixed I seriously dought it could be anything major.
13th September 2010
Posts: 13,150 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
I see it's your first post. Hello from Pittsburgh and welcome to the XLForum.
| Thread Tools |
| Display Modes |
