The Sportster and Buell Motorcycle Forum Sportster Specialty
Figure Machine
Dead Creek Cycles
Get Lowered
Primordial Cycles
Speedway Instruments
Old 22nd September 2010
coletrain777 coletrain777 is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: 1985 FXRT custom
coletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enoughcoletrain777 will become famous soon enough
Default Chain alignment???
How do you make sure that the chain is properly aligned (even) on an ironhead. Every bike I have ever owned had marks on the swing arm and the adjusters to let you know when you were in the same spot on both sides... my ironhead has nothing. There has to be an easier/better way than eyeballing it or using a laser level. So what's the secret
83XLX's Avatar
83XLX 83XLX is online now
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
I always measure the distance from the swingarm pivot to the axle on each side. A narrow tape measure makes it pretty easy.
fergerburger's Avatar
fergerburger fergerburger is offline
Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the rough
I check the alignment by riding it. check the direction of steering when riding no hands. seems to work
ryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really nice
A ruler on each sprocket should intersect in a straight line.
Use axle spacers and sprocket offset to align, hopefully the frame is straight.
Ryder Rick "If life doesn't kill me, nothing ever will."
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
Sportster/Buell Year: 1981
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
Me too. That, and just look at the dust, etc. pattern on the rear tire, after going in a straight line on a level surface.
Doesn't have to be to the mm exact.
Question Authority
Thanks for the replies guys, I guess I just like to be pretty exact when it comes to chain and rear tire angles. I even used to mark the rear axle slots when I would build a rigid frame for other people so they would be able to know that the wheel was "exactly" straight. I will use the measure and eyeball system, good enough for me!
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Hopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to all
Easy. Measure the amount of adjuster sticking out past the locknut on each side.
jonnybravo jonnybravo is offline
Banned
Sportster/Buell Model: Ironhead Chopper
Sportster/Buell Year: 84
Other Motorcycle Model: Kaw Z1 900
Other Motorcycle Year: 1973
jonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura aboutjonnybravo has a spectacular aura about
get out your chalk box, pop a line on a flat surface, roll bike to line also can check tracking this way
Keep it running Keep it running is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1984
Keep it running will become famous soon enoughKeep it running will become famous soon enoughKeep it running will become famous soon enoughKeep it running will become famous soon enoughKeep it running will become famous soon enoughKeep it running will become famous soon enough
Don't know if it is right but I did mine with a 4 ft carpenters level against the tire then backed up and eyeballed it. Seems to go down the road OK.
1984 XLS Roadster, 42K miles, SU carb, HI-4 Single Fire, Pipes and Andrews Y Cams. Had it long enough I am the PO ;-(
ezmerf's Avatar
ezmerf ezmerf is offline
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
I know this is probably not the best way but it's the way I've done it over 40 yrs.I eyeball the tire and swingarm,thats seemed to have wkd 4 me.I don't know but I think that's as good as trying all the measuring.
Murphy's Law
