Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Biltwell
Speedway Instruments
NHRS Performance
Get Lowered
Marks Moto Gear
Old 24th October 2010
joey7508's Avatar
joey7508 joey7508 is offline
joey7508 is on a distinguished roadjoey7508 is on a distinguished roadjoey7508 is on a distinguished road
Default cut down custom riser today
I had already cut down a 2003 custom riser. It looked great, but didn't have a good place to put the speedo with the 4.5 gal tank. So i cut down my stock 2007 custom riser. I know it has already been done by a few people on here. But I figured I would share anyway. I cut the riser down 2.5" you kinda have to cut it at an angle to get it to sit right. Then I drilled and tapped it useing the cut off piece as a guide for the hole placement. That left the wires and brake line a little long it would have worked just fine, but I had a set of nightster handle bars laying around so I put those on. They have about 1-1.5" of extra rise in the bars. So it took up the extra slack in the brake line and wires. Plus it gave me enough extra room to flip my mirrors. Here are some pics of the finished product. I didn't take pics while doing it sorry.
joey7508's Avatar
here are some pics of the 03 riser I cut down same thing different riser.
ReddTigger's Avatar
ReddTigger ReddTigger is online now
Red Beard Cycles
Other Motorcycle Year: ALL
ReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud of
Looks good. Nice work.
I AM THE REAL BAT-MAN!
You Can't Fix
STUPID !
Originator of the "NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,
Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
Old 18th November 2010
mayo92's Avatar
mayo92 mayo92 is offline
Sportster/Buell Model: XL883C
mayo92 is an unknown quantity at this point
looks good im wanting of doing this to my 2009 XL883C and would like to know if you could give me the details of how you did yours. how did you cut it, what did you use, how far you measured it, with it shorter do the mounting bolts still have a strong hold? and anything else you could tell me id really appreciate it. thanks....
-Mayo92
XL883C
Individuality is the fingerprint of the soul
edwilson29's Avatar
edwilson29 edwilson29 is offline
Sportster/Buell Model: XL1200C Vivid Black
Sportster/Buell Model #2: Buell XB9
edwilson29 is on a distinguished roadedwilson29 is on a distinguished roadedwilson29 is on a distinguished road
Looks good!!!
I also cut mike but I didn't cut it on an angle like you said you did. Mine sits more upright but I can still see my speedo just fine...
2007 XL 1200 Custom
SE Heavy Breather, Thunderheader, PCIII, Superbrace,
Road King Air Shocks, H-D Low Sissy Bar, those neat little turn signal eyebrows,12" apes, Ricor Intiminators , various chrome acc., More mods planned....makin it MINE!!!!
DO [U]SOMETHING[/U], EVEN IF IT'S WRONG!!!
edwilson29's Avatar
-Mayo92
XL883C
I cut mine on a large bandsaw at work.
I used the same bolts that came from the factory, just drilled and tapped the hole to same size.
Old 22nd November 2010
joey7508's Avatar
Yeah I cut mine with a hack saw very slow and careful. Checked it with a 2" tick piece of plate steel to check it on when I cut mine sure it was true. Used the cut off piece to line up the new holes drilled and tapped them and reused the original bolts. Just be careful when you cut through the chrome, same if you use a file to true it up or you will lift the chrome on the edges. Use the riser bolts and clamp bolts to hold the riser still in a vise and it makes it pretty easy. One thing to remeber is the brake lines and wires will be long once you cut some height off the riser. No big deal. I put nightster bars on mine when I cut it down. The nightster bars are slightly taller and wider. So it made it just the right length. And looks better, but keeps my hands in about the same place they originaly were.
casper883R's Avatar
casper883R casper883R is offline
Sportster/Buell Model: XL883R
casper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura aboutcasper883R has a spectacular aura about
A very very nice job!!!!! I like it more than the original......
I ride purely and only, because it is fun. I ride because I enjoy the freedom, I feel from being exposed to the elements, and the vulnerability to the danger that is intrinsic to riding. I don't ride to impress. I do not ride because it is fashionable to do so....
I love riding my Sportster 883R...
racerwill's Avatar
Super Moderacer
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Year #2: 80
racerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant futureracerwill has a brilliant future
nice job....
Ww
master wizard
RIP Mr Jimi
Old 16th December 2010
Other Motorcycle Model: XLH
Other Motorcycle Year: 1972
sportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant future
Nice "personalization", and black and chrome is always a good look. Best wishes for the Holiday season.
I.B.A.#26543, Old age and treachery ALWAYS overcome youth and skill! ******** Growing old-Mandatory/ Growing up-optional. Men do not quit playing because they get old, they grow old because they quit playing
