mike, Rick572 (70), Tailchaser (69), Back Road (53), sanman12002003 (52), LilMsRida (52), wargod1 (48), tplyons (30), DOM! (29)
black out, paint
Old 28th October 2010
freeidaho's Avatar
freeidaho freeidaho is offline
freeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to beholdfreeidaho is a splendid one to behold
Default How To Black Out
Howdy,
I am really liking the Nightster look, or the blacked out look. Just finished looking through many of the photo's on this forum and liked the Liam look.
What paint can be used to paint the forks, etc. Enamel, Epoxy, What? Can a rattle can be used, or does a professional booth/spray gun need to be used?
I assume that the surface is scuffed with a DA sander and then the paint is applied? Does it need to be baked?
Thank you in advance for your advice. And sorry if this horse has already been beaten, I didn't find much with a search.
kr
khaskins's Avatar
khaskins khaskins is online now
Other Motorcycle Year: 1970
I would powdercoat them. You can paint them but someday you paint them again. I'm sure that you could do a good job with a rattle can, if you disassemble and mask well you could do them on the bike.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
921200hd 921200hd is offline
Sportster/Buell Model: 92 sportster 1200
Sportster/Buell Year: 92
Sportster/Buell Model #2: my other ride has tits
921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about921200hd has a spectacular aura about
i agree i painted mine with a rattle can as best as any body can and with dirt rocks bugs and anyother thing you can think will chip it away powder coat is much better and its two forks how much can it cost really this is what ill be doing to mine over the winter POWDER COAT save the hassle of doing it twice
Old 29th October 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
Yeah, I'd also recommend powder coating them. If you do rattle can 'em don't use a sander just get a scotch brite pad and scuff 'em up some so the paint will have something to stick to.
[SIGPIC][/SIGPIC]
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
freeidaho........
You can also use this stuff..........but like powdercoating, it's baked on and will require removing and disassembling your forks. You can do this stuff yourself though.
www.kgcoatings.com
Stuff: YES
fatty883's Avatar
fatty883 fatty883 is offline
Sportster/Buell Model: XLH 883 Sportster
fatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of lightfatty883 is a glorious beacon of light
Yo Freeidaho, welcome to the forum...
Jonathan Seagull discovered that boredom and fear and anger are the reasons that a gull's life is so short, and with these gone from his thought, he lived a long fine life indeed...
freeidaho's Avatar
Howdy,
Thank you gentlemen. I will look into each of these. I am also a gun guy, so the KG coating is interesting to me too.
Editted to add: Based on the recommendation I checked local Powder Coaters. Three days turn around and $75 for fork legs and rear fender brackets. I Like It !
Thanks again,
kr
freeidaho's Avatar
Okay, me again,
How about powder coating the stock exhaust? Will it stand up to the heat over the years?
Thank you for your advice,
kr
linkin5's Avatar
linkin5 linkin5 is offline
Other Motorcycle Model: Honda XL 125
Other Motorcycle Year: 1982
linkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nicelinkin5 is just really nice
High temp paint or charco grill paint is the stuff for exhausts it will need to be done once in a while but looks good and holds up better than most stuff.
freeidaho's Avatar
Thank you,
I recall skimming some threads on high temp paint. I will use the search engine to find out more.
Thanks again,
kr
