Biltwell
Licks Holiday
Ricor Shocks
Old 6th November 2010
tink409 tink409 is offline
Sportster/Buell Year: 1981
tink409 is an unknown quantity at this point
Default iridium spark plugs
anybody run these in the iron heads? any feed back on them would be great..thanks
alaska62sporty alaska62sporty is offline
Sportster/Buell Model: '74 XLCH engine
Sportster/Buell Year: 62
alaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura aboutalaska62sporty has a spectacular aura about
I have never run run in an Ironhead, but have pulled them out of several carburated boat engines. I would avoid them. Iridium and Platinum plugs are good for fuel injected engines with O2 sensors and the like, they can last alot longer than copper core plugs in ideal conditions. The problems I have seen with them is that once they get slightly fouled, they are done. Fuel injected boat engines, say a 350 vortec chevy, run alot richer than car engines. They do this to keep cylinder temps down. Running rich fouls plugs. With a copper core plug, you run it up in the RPMs, with a load on it, you will burn the crap off the plug and life is good. The precious element plugs seem to not clean up like the copper ones do. I am not a chemisist, dont ask me why, but I have fixed many misfires by changeing platinum and iridium plugs back to copper.
Tag-less
ironhead red's Avatar
ironhead red ironhead red is offline
Sportster/Buell Model: XLCH Stroker Chop
Sportster/Buell Model #2: XLH Bobber
Sportster/Buell Year #2: 1977
Other Motorcycle Model: XLH Project ?????
Other Motorcycle Year: 1980
ironhead red has disabled reputation
I have been running the same Denso 0.4 Iridium plugs for 3 years. But, They don't make these for our engines. I machined my heads to accept them.
Ironhead Red
11 Second "Antique" Street Chopper Builder
ok thanks for the info. good to know
ryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really nice
Don't bother.
Many times exotic plugs that were not OEM equipment will cause problems.
I have seen this plenty.
Ryder Rick "If life doesn't kill me, nothing ever will."
Fe Head Fe Head is offline
Sportster/Buell Year: 1979
I found a set of the iridium fine wire ones that fit most GM 305 engines have the same overall reach.
I machined off the chamfered sealing part and placed a regular gasket over the threads - quite tight - and used them with no problems.
They have a much denser plasma arc and did not foul up nearly the same as the OEM ones.
In my case the irregular miss of the rear cylinder disappeared also.
I would, however, recommend swapping the front and rear ones every few thousand miles to nullify the the effect of our dual fire coils always having one plug's centre electrode negative.
This has been shown to wear down the fine centre elrectrode moreso than if its polarity was always positive.
Cheers;
Old 7th November 2010
mycle1000 mycle1000 is offline
Sportster/Buell Model: xlx61
Sportster/Buell Year: 85
Sportster/Buell Model #2: xl1200r
Sportster/Buell Year #2: 05
Other Motorcycle Model: yamaha vstar 650 custom
Other Motorcycle Year: 00
mycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nicemycle1000 is just really nice
for an ironhead i have discovered the harley plug "xl 10 s" which is like the split fire, when used with a se coil works quite well. it takes the cold-blooded out of starting and adds to the fuel mileage.
85 xlx61 (with a million miles and a million mods)
05 xl1200r (bought used)
00 vstar650 (for the wife)
forqueue forqueue is offline
Sportster/Buell Year: 1976
forqueue has disabled reputation
Off the shelf NGK Iridium BR7HIX (7067) with a .065" index washer for depth correction.
Not a problem in 3 years. Running with a single fire electronic ignition.
wlkilmer's Avatar
wlkilmer wlkilmer is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: Heritage Softail Classic
wlkilmer has disabled reputation
NGK iridium BPR6HIX or BPR6HIX will fit.
Hmmm, nice to have a choice, eh.
