The Sportster and Buell Motorcycle Forum CV Performance
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Sportster Specialty
Zippers Performance
Primordial Cycles
Zippers Performance
Old 15th November 2010
McC2430's Avatar
McC2430 McC2430 is offline
McC2430 will become famous soon enoughMcC2430 will become famous soon enoughMcC2430 will become famous soon enoughMcC2430 will become famous soon enoughMcC2430 will become famous soon enoughMcC2430 will become famous soon enough
Default Warning Lights
What problem is supposed to be indicated when both the Yellow Engine and Red Battery lights light up and go out in concert with one another?
I looked in the owners manual and it doesn't list anywhere (I could find) about either light much less what they mean together.
I just want to know if anyone has a clue. I'd call the local Stealer but for the most part the one near me has part replacers not mechanics.
Thanks,
Larry
'04 1200C. Modified SE II baffles. 12" mini-apes internal wires. Road King shocks.
SANMAN18's Avatar
SANMAN18 SANMAN18 is offline
Sportster/Buell Year: 06
Sportster/Buell Model #2: XL 1200/Buell Drag bike
Sportster/Buell Year #2: 1994
SANMAN18 is on a distinguished roadSANMAN18 is on a distinguished road
it used to do it on mine, replaced the battery and voila.... went away. not sure if thats what they mean but it "helped".
2006 1200R, V&H short shots, ThunderHeart 5075 Ign, SE Heads, SE 536 Cams, SE High Compression Pistons, SE Clutch
Old 16th November 2010
jimmyess333's Avatar
jimmyess333 jimmyess333 is offline
Sportster/Buell Model: none
jimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of lightjimmyess333 is a glorious beacon of light
The battery light is the main indicator coming on.
Since the computer is picking up a trouble code it causes the "check engine" light to come on too.
Check your battery cables and also check the codes to see if it's a low voltage code.
If that doesn't fix it test the battery then the charging system.
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
Thanks,
Larry
They'll probably tell you to replace the entire bike!
Stuff: YES
