The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 1
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > EFI Sportster Motorcycle Talk (2007 and up)
NRHS Performance Long 2
Get Lowered
Old 24th November 2010
Charlie Boy's Avatar
Charlie Boy Charlie Boy is offline
Sportster/Buell Model: sportster Forty Eight
Charlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the roughCharlie Boy is a jewel in the rough
Default Can someone tell me the difference between the VIED and the X14iED
Can anyone help me out?
roadtrip's Avatar
roadtrip roadtrip is offline
Non-ancraophobic
Sportster/Buell Model: XL1250C
roadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud ofroadtrip has much to be proud of
http://www.nightrider.com/
all your questions will be answered
Bear say's:
Experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
I am seeking info here not from their website. Thanks
BKB's Avatar
BKB BKB is online now
BKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to allBKB is a name known to all
I believe the VIED is user variable for A/F ratio. It allows you to fine tune your air to fuel ratio a little more, like from 14.7 to 13:1. It does not vary the A/F per RPM or anything like that tho. It still only fools the ECM into altering the ratio accross the board. The X14EID only changes the A/F ratio from stock 14.7 (IIRC) to 14:1. I'm sure if this is not correct, someone will chime in with more accurate or comprehensive info on this.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
I didn't buy a Sportster 'cause I wanted a Harley... I got a Harley 'cause I wanted a SPORTSTER!!! He who gives up liberty for security, will have neither. Ben Franklin
smokin'ron's Avatar
smokin'ron smokin'ron is offline
smokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura aboutsmokin'ron has a spectacular aura about
The only difference i know of is that the X14iED is fixed At an AFR of 14:1 where as the ViED allows adjustments between 13.8:1 and 14.3:1.
Unfortunately, that is all I know of. I bought and install the X14iED after installing my straight shots and have been happy since. It has leveled the bike at specific RPMs and has greatly reduced the heat it puts out. Once in a great while, the bike will rev at idle and it takes a minute to adjust itself, it did not do that before the iED install, so I assume that's just the product doing it's job.
