15th July 2005
Replace them that is.
15th July 2005
Luvs me an artsy chick...
Posts: 11,674 Sportster/Buell Model: 883>1200 XLH Sportster/Buell Year: 97
Originally Posted by HotRodSporty
Will I have to replace my head gaskets?
If ya don't have'em, and you wanna ride NOW, you can probably reuse them....happened to me...but unless they look pretty original, at SOME point you'll want to chang'em...
~Chuck
Occam's Razor...
Chuck's favorite tuning posts
15th July 2005
Posts: 692 Sportster/Buell Model: Custom 1200C Sportster/Buell Year: 2003 Sportster/Buell Model #2: I wish
They are the muliti layer metal SE high performance gaskets. I just talked to a local motocross racer that knows a ton about bikes, he said I should not have to replace the gaskets, to loosen the head bolts to 8 lbs and then re torque them and due the 90 degree turn.
But because its only doing this under load then goes away even when riding, so its only making this noise under load, he thinks its too lean and told me to go to a bigger main. Wich for some reason last time it was dyno tuned , they put a 155 in it. I will re torque the head bolts and throw a 165 in it and see if that does it.
15th July 2005
Master Bike Builder
Posts: 2,039 Sportster/Buell Model: 883-1380cc hot rod Sportster/Buell Year: 87 Sportster/Buell Model #2: wife's 883-1200 Sportster/Buell Year #2: 87
Re-torque the bolts and ride it and see what it runs like. You cant judge jetting with loose heads. If you hear sounds like a hammer hitting tin when you try to accelerate, it is "pinging", "spark knock", "detonation", whatever you want to call it. If so, back the timing off a few degrees. I'm gonna guess you didn't hurt the gaskets unless you rode it a long way.
Ted
Still crazy after all these years.
Late 87-883 Hugger/1380cc (84") conversion. Too many cool parts to list. Built engine on a fresh set of cases, so conversion might not really describe it. Estimated near 115 hp.
Early 87-883/1200 conversion. Wife's bike. SE heads, 1200 flat pistons, 40" Drag Pipes, everything else stock.
"Wise men speak because they have something to say; Fools because they have to say something."
Plato
15th July 2005
Posts: 183 Sportster/Buell Model: sportster 1200S Sportster/Buell Year: 2001
My god a 155 main with the exhuast and carb you have, 165 at least and I would say one richer needle as well, maybe the 4 th slot on that needle as well , but try the middle slot first. Have you read the carb tuning section . It will help. I have a 42 with a open exhaust I run a 167.5 with the next richer needle on the middle slot. I have the cams and a 3 inch hurricane , But check the plug there is a plug chart as well on this site.
Good luck dude
2-1 hindle/42 mikuni/se 6500 ignition/heads stage 2/se boltin cams/trak-tek 400/ se leads/Fournles air rear shocks/ ;)
15th July 2005
I dont htink that the head gaskets have anything wrong with them, I know the 155 is small, thats been determined already as I stated in my last post, and I know how to look at my plugs, they look fine, Like I stated already I will re torque my heads and tune the carb a bit, and unless aswrascing tell me to do anything different , I think this will work, I have talke to two good mechanics locally and have been told what to fo. Thanks for the help and advice.
| Thread Tools |
| Display Modes |
