Phil R (70), powellsanmiguel (66), pasqualeddpas (58), gmhsc (55), roachhill (43), redi2ride (39), eliminator96 (33), Booncha57 (32)
Ironworks Magazine
Figure Machine
Primordial Cycles
Foxcreek Leather
Old 21st December 2010
lucky23's Avatar
lucky23 lucky23 is offline
Sportster/Buell Model: XLCH Sportster
Sportster/Buell Year: 1972
lucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the roughlucky23 is a jewel in the rough
Default welding the kickstart ratchet to the clutch shell?
Anyone ever done this? I was thinking it would be easier and stronger to tig weld the ratchet plate to the clutch drum instead of the rivets. Anybody have any advice on this
www.combustioncontraption.blogspot.com
big andy's Avatar
big andy big andy is offline
Sportster/Buell Year: 1973
big andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nicebig andy is just really nice
hi lucky23 i would not weld the ratchet in place due to heat distorsion of the ratchet plate and clutch hub this is only my opinion not only that when you need two replace it you could grind to much metal away and have problems engaging the ratchet with kicker gear but its your call goodluck
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
If the whole thing was heated up before hand it would minimize distortion but still a tricky operation.The clutch drum is probably hardened also, so you would need to get it heat treated after welding.
Old 22nd December 2010
fergerburger's Avatar
fergerburger fergerburger is offline
Master Bike Builder
Sportster/Buell Model: 71 xlch
Sportster/Buell Year: 73
Sportster/Buell Year #2: 74
Other Motorcycle Model: BT rigid hand shift
fergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the roughfergerburger is a jewel in the rough
weld away.....the starter ring gear can be welded with no distortion or problems.
I have never had a problem with rivets....probably due to the fact I have a brake manufacturing company down the street that sets rivets for me for free using the correct equipment and high quality materials.
Matt397's Avatar
Matt397 Matt397 is offline
Sportster/Buell Model: XLH stock/near stock
Matt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura aboutMatt397 has a spectacular aura about
I welded mine (mig) without any problems. Four short welds of approx 1/2. I was going to tack it only then drill for rivits but it came out so well I skipped them. Never set rivets before and didn't feel comfortable with the process. Heat wasn't a problem (the starter ring gear was welded in spots).
Setting rivets 101 would be a great stickie post here in the forum,..any pros?
Matt
lucky23's Avatar
Thanks for the replies! I guess I could take it in to a brake place here, but Im just not sure exactly how the holes on the inside of clutch shell should be drilled. Do the holes have to be counter sunk on the inside to leave room for the rivets to expand when you flatten them?
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of lightericfreeman is a glorious beacon of light
I have the rivets along with 4 small welds to hold my ratchet plate in place. I believe the ratchet plate is countersunk slightly for the rivet heads but the holes are a little too deep to properly contact the rivet when peening the end using the alignment tool. Results in rivets that are not as tight as they should be if they were backed up individually. Mine appeared fine at first but when I opened the primary later on after some miles, the ratchet plate had a slight amount of movement on the rivets. That's when I tacked the plate in place.
Eric
lucky23's Avatar
Interesting. I remember reading somewhere that you can drill and countersink shallower holes next to the existing ones on the ratchet and that does the trick for getting the rivets at the correct depth for a tighter peen?
lucky23's Avatar
But Im still wondering if i should drill and countersink holes on the INSIDE of the clutch shell?
IronHead78's Avatar
IronHead78 IronHead78 is offline
Sportster/Buell Year: 78
IronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura aboutIronHead78 has a spectacular aura about
I know mine is welded,it was done before I got the bike. I can't remember if the holes inside are counter sunk or not.
78 sportster, Weisco pistions,Andrews Y cams, Kibblewhite valves with Manley springs, ported and polished heads with an SS super E.
