Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
NHRS Performance
Get Lowered
Old 21st December 2004
E00i3's Avatar
E00i3 E00i3 is offline
Sportster/Buell Model: 883>1200 XLH - Black
E00i3 has disabled reputation
Question Changing out a rear fender, how difficult?
I had a Bobtail fender installed on my Sporty when I got it a year ago, now I am thinking of installing the original rear fender. How hard is it to replace the fender? Would I need a motorcycle lift for this?
Thanks,
Eddie
Shark Doctor's Avatar
Shark Doctor Shark Doctor is offline
Shark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the roughShark Doctor is a jewel in the rough
Not difficult; be patient. Reinserting the rubber grommet that serves as a passage for the wiring is a minor challenge. You'll prob have to reattach the foam conduit that carries the wiring to the taillight assembly to the underside of the fender.
I've found that using thin, light cotton gloves (like the photo store techs use) is a really great way to handle tin.
Why the change from the bobtail look (pretty classic)...
Old 22nd December 2004
Moved On Moved On is offline
Your bike looks pretty high in the back so this might not be an issue for you. Sometimes the bolts in the rear struts will hit the tire when you try to remove them. They pull out towards the inside. You might need to drop the swing arm to do that, lift the bike and remove the top shock bolts. Actually as I'm writing this I wonder if you need to remove the top shock bolts anyway... I don't know the answer to that one???
There are plans to a nice inexpensive lift that Gronk and someone else (I just can't remember who that was right now, maybe Billy) did in the download section of the old site. You need to be a premier member to gain acess to that area though. There is also an even cheaper lift you can make here: http://www.nightrider.com/biketech/bikelift.htm
Gary
E00i3's Avatar
Yeah i think it is like 13 inch shock! I just bought some HD lowering shocks. When i bought my bike, I got the bobtail because i really liked how different it made the bike look. Well i am just curious to see what it will take to change the fender.
Gary: Do you have anymore pics of your sporty? I dig the whitewalls man!
Thanks for you feedback!
Last edited by E00i3; 22nd December 2004 at 02:16.. Reason: Wanted to add more to my post
Thanks, they're different. I like them too. I just put a bunch of pics in my gallery.
Gary
E00i3's Avatar
Great looking bike... I really dig the white walls...
Yea the WW are nice, but we can keep it our secret that it's the stripe on the gas tank that really set's it apart from the rest
Gary
woody95's Avatar
woody95 woody95 is offline
Sportster/Buell Model: 883/1200 Hugger
Sportster/Buell Model #2: 883 Custom
woody95 has disabled reputation
Gary:
What make are those tires. They look great. Never thought WW would look so good on a sporty.
Bob
They're Avon Venoms.
The Avons (and Maxxis, I think) are the only ones I found which will fit an XL. Avon also has a "Ganster" line with an even thicker stripe which will fit on the rear. You can seen them on some of the Bobber bikes ove at Licks.
This looks like the "Gangster" on the rear:
This looks like the "Venom" on the rear:
Gary
E00i3's Avatar
I dig those bikes from Licks!!! I am gonna have to play with photoshop tonight and see what my bike would look like with WW and Mini Apes... When i got my sporty, i wanted a more dagger type look... but ever since I saw that one biker build off with that bobbers type, I just really liked the style...
What are those plastic coverings on between the forks and the triple trees?
Very nice!!
Similar Threads
Rear fender scratches invaliduser Sportster Motorcycle General Discussion and Problems 5 25th April 2005 18:10
'04 rear fender jrmkel Sportster Motorcycle General Discussion and Problems 2 22nd April 2005 22:25
Rear fender struts Turboharleyproject Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 5 11th March 2005 04:15
Rear Fender Brace 2001 Sporty TurboOtter Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 1 8th March 2005 22:29
grey box on rear fender FreeAgent53 Sportster Motorcycle Motor - Top End 11 10th February 2005 01:42
