The Sportster and Buell Motorcycle Forum Licks Tanklift
CV Performance
The Dart Flyscreen
Primordial Cycles
Sky Smith Insurance
  #101
Old 21st July 2012
brucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura about
battery positive terminal on the,battery ve,represent's,voltage.+,represent's,positive terminal on,battery. -,represent's,ground.
Old 21st July 2012
ezmerf's Avatar
ezmerf ezmerf is offline
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
On your bike you can do it on the reg by touching a wire from Bat terimnal to Gen terminal
Murphy's Law
Old 21st July 2012
mikethebike61's Avatar
mikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the roughmikethebike61 is a jewel in the rough
Originally Posted by xlh59 View Post
ahhh -- but that would be only the case, if there is a consumer attached to the generator, right? And the field coils would ghave to be grounded as well .... or am I wrong?
The generator had nothing attached to it ... no light, no horn, no ignition, no regulator - nothing. Without a consumer and a regulator and open field coils the generator should not produce more than 5 or 6 volts and ther would be no current, right?
mikethebike - I am trying to understand, so please correct me if I am wrong.
Was it wired to a battery?
Old 22nd July 2012
Grind1203 Grind1203 is online now
Grind1203 is an unknown quantity at this point
Thank you. I found another broken wire. So that should fix it then I will polarize the genny. I got more problems though. My bike has stranded me due to that broken wire. It's now fixed, I got all my lights back on but now when I go to kick it it's like there is no compression. Seems ok when the bike is stone cold. I was on the way to the shop who did my top end rebuild. I have a leaky front rocker box oil line that started seeping after the first 500mi. I am about 1000 miles into my break in period. 50-55mph for the first 500 miles and 60-70mph for another 1,000 miles I have been varying the speed like the sheet says. Oh and my rear header was like half way off the spigot. I think I found my fart issues.
Old 22nd July 2012
ezmerf's Avatar
I would adjust my valves per video in red stickies for the cold hot tells me yours valves are to tight.loosen oil nut all the way out wiggle tube around a little reinstall nut making sure you don't cross threat it and tighten it back up.
Old 22nd July 2012
Cool, thanks ezmerf! The bike is at the shop. Stupid kid taking me and my bike back on the trailer managed to snap the kickstand off! luckily it was the stand and not the mount on the frame.
Old 22nd July 2012
Cool, thanks ezmerf! The bike is at the shop. Stupid kid taking me and my bike back on the trailer managed to snap the kickstand off! luckily it was the stand and not the mount on the frame. I'll make sure the Indy knows to double check those pushrods. Sorry I know this is a voltage reg thread, I really appreciate the help. I'll make a new thread when something new comes up.
Old 22nd July 2012
ezmerf's Avatar
You sure the kick stand broke?Most time it's the retaining pin has only worked it's way out.
