11th April 2011
Posts: 485 Sportster/Buell Model: XL883 Sportster/Buell Year: 2006
Lux,
All that makes sense to a degree, but I would have never guessed that it was 24 oz. Isn't that like 20% of the total capacity. Seems a lot to me.
Thank you for your more detailed reply,
kr
+-+ freeidaho -at- yahoo -dot- com ........................... There is a $5 fine for whining.
|---\ http://www.parmarng.org/freeidaho/default.html ......... You are what you do, everything else is just talk.
|----| http://xlforum.net/vbportal/forums/s...d.php?t=999415 . Eat, sleep, live, love and ride motorcycles.
/-----\ http://www.parmarng.org ..................... If life throws you a curve, lean into it and apply throttle.
|*------/\ ...............Wouldn't be an economic crisis if you had bought AMERICAN.
|--------| ...............Spent most of my money on cars, motorcycles, guns and girls, the rest I just wasted.
+--------+ ...............Silence is taken as consent. Do you consent?
11th April 2011
Posts: 4,297 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006
Originally Posted by freeidaho
Lux,
That's what I was thinking - somewhere near 25% of the oil which is NOT changed!
I'd be interested to know how much cleaner the oil is at the next and subsequent changes as well.
Getting through the Break-In Miles Sucks!
11th April 2011
Leg Man!
Posts: 3,709 Sportster/Buell Model: XL 1200 Custom Sportster/Buell Year: 2004
Lux,
kr
Yep, you can drain about 2.8 to 3 qts. out if you didn't use any oil between a change. That makes the total capacity of the motor 3 qts. 20 ounces which as stated in the manual is about 3.6 qts. That means in reality, on a normal change you're leaving about .6 qts. of dirty oil in your motor which is:
.6 qts. / 3.6.qts. which equals 16.7% of the capacity.
That's like draining 5 qts. of oil out of my truck and putting 4 qts. of fresh oil in and adding back 1 qt. of the used oil.....no way anybody would want to do that. Dry sump vs. wet sump. This is a great way to deal with it.
11th April 2011
Leg Man!
It's noticeable right now! But I'm sure it'll get cleaner every time. Another thing to think about..... A lot of guys switch to Synthetic oil over dino sometime during their bike's lifetime. That means that when you switch you really are mixing about 20% of the old oil in with the new. Theoretically you'd never be completely synthetic till you scavenge!
11th April 2011
Posts: 338 Sportster/Buell Model: Nightster Sportster/Buell Year: 2007
How many quarts did it take to do the scavenger method?
Is it about 4 quarts?
12th April 2011
Leg Man!
Yes, I used 4 quarts exactly. But since the motor holds 3.6 quarts if you drain ALL of the oil, I only over pumped about .4 quarts.
So....you're not really wasting the extra oil....you're changing out all of it. If your car holds 5 quarts of oil you wouldn't drain out only 4 quarts and put the plug back in and top it off with 4 quarts of new oil would you? Buts thats about what you do if you don't scavenge all the oil in your Sporty.
You start by adding the recomended amount for an oil change which is 2.8 to 3.0 quarts. Then add back only what you pump out while scavenging. I could have probably stopped at around 22 to 24 ounces but I decided to pump out exactly a quart...that way I'm sure I got all the dirty oil out plus it's easier to just dump in a whole quart rather than measure it out. I guess I could have stopped at 24 ounces, added the same amount, and left myself 8 ounces in the AmsOil bottle for "topping" off oil. Next time I may do that. It was just easier this first time to pump out a whole quart.
12th April 2011
Posts: 2,879 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2002
I would do this but with my luck I would forget to put the plug back in or it will somehow fall out on me or something.
Here is another option for anyone who doesn't want to spend $90. on this kit.
Jireh Cycles sells this for $15. you would not get the oil left in the return line out but it would get everything else out:
CONTAMINATED OIL REMOVAL SYSTEM: Allows you to completely remove all old, contaminated oil from your motorcycle when you change the oil.
Part# 97-304
2002 XL1200C (originally)
Stage II Buel XB Heads, Andrews N4 Cams, Mikuni HSR42 Carb, Forcewinder Air Filter with Float bowl vent mod, S&S Roller Rockers, Jim's Powerglide Lifters, Thunderheader Exhaust, Daytona Twin Tech SIngle Fire Ignition, Crankvents.
Max Power=85.47
Max Torque=81.84
Flow Bench Results
12th April 2011
Leg Man!
The plug you refer to is no different than the one for your regular oil drain plug. Forget either one and you'd have a mess!
There's still alot of dirty oil left in the hoses, passages and pump. When you scavenge, you use the new oil to push out the old oil till it runs clean.
By the way, I'm not a spokesman for the Scavenger....just a satisfied customer.
Just looked closer at that gizmo you were talking about...looks like it goes in place of the filter? How does it work? It's not a pump like I first thought.
12th April 2011
Leg Man!
Found this on another site. Softail but the same idea.
The CORS (CONTAMINATED OIL REMOVAL SYSTEM) looks like an interesting gizmo, but if I understand it right, I'm not sure I would want to use it on a Softail. It replaces the oil filter right? And, if I understand correctly, it dumps the old cam chest oil without recirculating to the engine from the filter. Which means it is not feeding oil to lubricate the motor while it is purging the old oil from the cam chest. It won't flush the camplate or passageways. And it won't pull the oil from the crank chest since the recovery passageway sits up off the floor of chest and leaves a constant pool of oil under the crank.
The Scavenger may be overkill, but at least it purges that last bit of old oil, on the way back to the tank. It not only keeps the oil flowing through the engine, it allows for adding extra oil to improve the flush of the chests and passageways.
I'm not saying a purge is needed - but at least the Scavenger design keeps oil flowing through the engine during the process and allows for a complete flush. The CORS stops oil flow to the engine from the filter, and won't pull the largest pool of remaining oil from a Softail. just a thought...
12th April 2011
Posts: 1,213 Sportster/Buell Model: 1200 C Sportster/Buell Year: 09
Makes you wonder why the factory does not also install a crankcase drain...
Have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1, X14iEDs...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
| Thread Tools |
| Display Modes |
