6th April 2012
Senior Bike Builder
Posts: 1,996 Sportster/Buell Model: Custom Sputhe XR Sportster/Buell Year: 19** Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1965
Carb size depends what you are looking for.
When calculating throat size on my 77 CI XR, for all out HP throat size was something like 52mm per cyl.
Seems outrageous, but individual runner engines require more carb.
I'm not looking for topend power, I don't rev over 6000, I have run dual 40mm cv's and 38mm mikunis.
I don't recommend the cv's for individual runner applications.
Although they work fine after 2000 rpm, I found the vacuum slides did not work well at lower rpm's.
There's more details below.
Here's a link to my Sputhe XR:
http://xlforum.net/vbportal/forums/s....php?t=1151857
Dyno thread:
http://xlforum.net/vbportal/forums/s....php?t=1194750
6th April 2012
Posts: 5,135 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
ferrous head,does that sidehack racer have a,reverser? [im looking at the clutch release area on the cam cover]
7th April 2012
Senior Bike Builder
Posts: 1,942 Sportster/Buell Model: KHK Sportster/Buell Year: 1954 Sportster/Buell Model #2: XLC Sportster/Buell Year #2: 1958 Other Motorcycle Model: XLRTT Other Motorcycle Year: 1966
Cut down engine, it's got an AMC/Norton/Matchless/AJS gearbox...
Flat Head Forever...
7th April 2012
Posts: 1,610 Sportster/Buell Model: XLB, XLCH, Sporton Sportster/Buell Year: 1962 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1966 Other Motorcycle Model: XLCH (Another one) Other Motorcycle Year: 1966
He's running a non unit construction gearbox. Yup, heard me right. Bruce cut off the gearbox section of the engine, welded it up and added a TT Industries gearbox. It gives him the option of running 5 or 6 speed gearboxes plus those gearboxes will handle over 160HP with no problems whatsoever. Of course for $6,000 you want a pretty good gearbox.
The new Amals inlcude a MK2 Smoothbore version ()What Bruce is running) and they do an alcohol conversion. Sizing carbs isn't that hard, it's actually understanding (or admitting to) the kind of use your engine REALLY sees. If your going to run it on the street about the worst thing you can do is over-carburate. Makes the bike hard to start and hard to ride. Not what your after on the street. I have 2 different carbs for my Ducati, a 36 and a 38mm Amal. The 36 is for the shorter twisty tracks and the 38 is for places like Phillip Island or Eastern Creek with very long fast sections. But if I was riding it on the street it would go down to 32mm.
7th April 2012
Posts: 604 Sportster/Buell Model: XR 1000 Sportster/Buell Year: 1983 Other Motorcycle Model: Enfield Other Motorcycle Year: 2004
stock xr runs 36mm, for a hot setup I would think some flat side mikuni 38's, though I hate the way they look(I have one on my other bike)
7th April 2012
9th April 2012
Posts: 457 Sportster/Buell Model: xlh Sportster/Buell Year: 1979
Have you considered Del Ortos, as run on the older bevel Drive Ducati? They are available (new) in 32 to 40mm at bevelheaven. Mine (shown) were 32's that I bored to 36.5mm. What's nice is they run an accelerator pump and come in R & L versions
10th April 2012
Posts: 463 Sportster/Buell Model: xlcr Sportster/Buell Year: 1977 Sportster/Buell Model #2: Hardon sporty/norton hybr Sportster/Buell Year #2: 1962 Other Motorcycle Model: panhead Other Motorcycle Year: 1952
have ordered 2 36mm mikunis
thanks for the wealth of infromation
10th April 2012
Originally Posted by brucstoudt
before the thing will even run,you need to change the cam timing,on the rear cylinder,because the intake and exhaust valve locations ,are now reversed. its not a,simple swap.normally 2,front heads are used.
A rear cylinder head reversed on the front puts the valves in the same order.
The rocker box can easily be turned around so the pushrods stay on the right side.
One carb on each side, right side facing forward, left side facing back.
Ryder Rick "If life doesn't kill me, nothing ever will."
11th April 2012
good to know, anyone have any pictures of this set up?
| Thread Tools |
| Display Modes |
