The Sportster and Buell Motorcycle Forum Licks Tanklift
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
Sportster Specialty
Biltwell
Sportster Specialty
Old 23rd April 2012
Other Motorcycle Model: XLH
Other Motorcycle Year: 1972
sportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant future
Originally Posted by DaytonaSportster View Post
AWESOME Write up!!
I have a couple of questions...
I too have the same setup as you did before all this. But I need to tune it better as I only got 73hp and 66tq vs your 80hp/79tq. So which baffle were you running in the Caliber pipes? Mine came with a 1"3/4 and 2". My #'s were with the smaller baffle.
Next Q, why the swap from the TC88a to the IST? I thought they were the same thing just different labeling.
Oh I almost forgot, last Q, why the new heads? Yours were just as good as base units as the Buels.
F.w.i.w. the tc88a is a fixed map, where as the I.S.T. is an auto mapping unit, not even close to being the same. Scott: Motor mods looking real good, let me know how the I.S.T. performs for you. I'm curious how it would show on a dyno as it is constantly learning and making running corrections on the fly. Also, keep in mind that it will come with a 6,100 rev limit from S&S, this is to facilitate break in. The limit can be raised after your break in period.
I.B.A.#26543, Old age and treachery ALWAYS overcome youth and skill! ******** Growing old-Mandatory/ Growing up-optional. Men do not quit playing because they get old, they grow old because they quit playing
Old 23rd April 2012
Heavy_D Heavy_D is offline
Sportster/Buell Model: XL 883
Heavy_D is an unknown quantity at this point
Looks Great!
Wondering where you got your oil catch can breather from?
Old 23rd April 2012
~Grind~'s Avatar
~Grind~ ~Grind~ is offline
XLFR
Sportster/Buell Year: 04
~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future~Grind~ has a brilliant future
Thanks! The oil catch can came from J&P Cycles.
Old 24th April 2012
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to behold
I just read through this thread for the first time scott. As everyone has already noted you went the extra mile in many ways. Like everyone else, I am curious as to how the cams you and Len are running are going to work out.
I doubt either of you are likely to run into another street sportster with as much steam. Neither of you skimped on the supporting cast. I look forward to hearing how it runs. steve
Old 24th April 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
VERY nice Scott!!!
Stuff: YES
Old 24th April 2012
maru's Avatar
Educate me on this ignition system. Apparently I have been living in a cave. Presumably it incorporates some sort of knock sensing auto retard? steve
Old 24th April 2012
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Leg Man!
LuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant future
Here's a recent thread that was started:
http://xlforum.net/vbportal/forums/s....php?t=1430175
Old 24th April 2012
rocketmangb's Avatar
Jester Mafia
Other Motorcycle Model: 48
rocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant future
Steve,
Dem guys are Bums !
Better hope they dont venture to SoCal after I get the Queen running !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
Old 24th April 2012
rejeanprimeau's Avatar
rejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to beholdrejeanprimeau is a splendid one to behold
S&S have this ignition for a long time. My neighbor run one on a FX 100ci since 2001, no problem.
Old 24th April 2012
Lenster's Avatar
Lenster Lenster is offline
Lenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud ofLenster has much to be proud of
Scott, I think meticulous is an understatement. Wow. Just wow!
Getting through the Break-In Miles Sucks!
