Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Engine Conversions
The Dart Flyscreen
Speedway Instruments
Licks Holiday
Old 14th June 2012
tdd3748's Avatar
tdd3748 tdd3748 is offline
Sportster/Buell Model #2: XL 883
Sportster/Buell Year #2: 2005
Other Motorcycle Model: Ultra Classic 117 CI
tdd3748 is an unknown quantity at this point
Default 1200 conversion advice wanted.
I will say Thanks in advance to all who reply.
I am converting the little woman's bike; 883 to 1200 and I am on a relatively tight budget. I have scored XB12 heads and cylindesr w/pistons for $280. The cylinders have less than 2500 miles and when checked with a bore gauge are spot on for roundness/taper and piston clearance. That being said I have the option of using stock pistons and just re-ringing - saving $250-350 depending on pistons I would purchase. The down side in this is that since stock pistons are cast I don't have the option to open up the valve pockets in the pistons and the stock valve pockets will limit cam selection (wanted SE-536's).
Hammer is going to do my heads - My question: Should I get the Impact (Stage I) porting and get new (stock bore) forged pistons so I can install SE-536's; or should I get the Smash (Stage II) porting and use the stock pistons and pick another cam?
If only I could hit the lotto the question would not be on the table.
Thanks Tom
Old 14th June 2012
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
I do not know what the cost difference is, but since you are not going to get in that engine every weekend I would save a few duckets and do it the way you really want it to be.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Old 14th June 2012
ReddTigger's Avatar
Red Beard Cycles
Other Motorcycle Year: ALL
ReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud ofReddTigger has much to be proud of
Have you spoken with Hammer regarding cam selection and piston selection ?
I AM THE REAL BAT-MAN!
You Can't Fix
STUPID !
Originator of the "NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,
Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
Old 14th June 2012
tdd3748's Avatar
You are correct Wedge I could wait till riding season was over and do it this fall - but truthfully I would like to have it done and broke in before our first long trip of the summer mid July.
Redd - yes I have been talking with Dan but until today when I got the cylinder specs was going down the new piston/bore path using SE-536's and just having the XB heads freshened up.
