Figure Machine
Biltwell
Old 17th June 2012
(WI)IceDevil's Avatar
(WI)IceDevil (WI)IceDevil is offline
(WI)IceDevil is an unknown quantity at this point
Default Mid-range strangeness...
I'm new to Harley's (and bikes in general), so bear with me and my very limited knowledge.
I'm getting some strange noises when cruising in the mid-range. It's not a pop or a backfire, more like the sound of someone shaking a few stones in a metal watering can. It seems like the sound is coming out the pipes, as opposed to from the motor. Only happens in 3rd gear @ ~30 mph and more noticeable in 4th @ ~40-50 mph. Any ideas?
I know she needs a good carb cleaning (possibly new jets) and could probably use plugs and wires (points & condenser too?). I'd really like to make this last.. absolutely love the bike. Like I said, I'm new to this.. so, please, be gentle.
-Jim
Old 17th June 2012
2nd @ 30 (in town cruising) seems slightly absurd... Maybe I'm just not used to high r's on two wheels, as I've been on four for waaaaaaay too long.
Old 17th June 2012
ryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really nice
Detonation?
Valve adjustment?
Who knows, I can't hear it from here...
I can say for sure that,
You should not ride it unless you are sure that everything is right,
or you will find out just how fast one can eat itself up.
Jets don't wear out. However the stock low speed jet is often undersized for a motor that has been modified to improve airflow (air filter / exhaust).
Ryder Rick "If life doesn't kill me, nothing ever will."
Old 17th June 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Turbo Mafia Test Pilot
Other Motorcycle Model: FXDL
I usually shift to 3rd around 40 if I'm riding normal if that helps.
Old 17th June 2012
AustinXL's Avatar
Just re-read the post and totally missed the part about stones in a can before! Sounds like it could be detonation?
Old 17th June 2012
Hmm. I definitely don't know enough to diagnose and/or fix this problem.. kinda' discouraging given the cost of labor these days. I s'pose.. ya gotta start learning somewhere.
I'm sure that, given my luck, when this ship comes in.. I'll be at the airport.
Thanks guys.
Old 18th June 2012
Originally Posted by (WI)IceDevil View Post
... I'm getting some strange noises when cruising in the mid-range. It's not a pop or a backfire, more like the sound of someone shaking a few stones in a metal watering can. It seems like the sound is coming out the pipes, as opposed to from the motor. Only happens in 3rd gear @ ~30 mph and more noticeable in 4th @ ~40-50 mph. Any ideas? ...
You may be going too slow to be using those gears? Maybe lugging the engine?
Do this, from the Technical Stickys ...
IronHead Noise - Using a Stethoscope
http://xlforum.net/vbportal/forums/s...d.php?t=832376
Old 18th June 2012
sportsterdoc's Avatar
sportsterdoc sportsterdoc is online now
Bike Builder
Other Motorcycle Model: Triumph Bonneville
sportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to allsportsterdoc is a name known to all
30 MPH in third is good if you are downhill and the throttle only cracked.
Harleys have great low end torque, but still do not like being lugged.
+1 to IronMick's comments.
Old 18th June 2012
Speeds noted. Thanks.
I'll get on that, Mick. Thanks.
Being green, wet behind the ears, noob etc. sure is exciting. Hopefully, it isn't too costly.
Old 18th June 2012
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about
How about maybe your license plate bracket, rear fender or chain guard rattling. My chain guard was making a rattling sound, it was cracked and after getting it welded, noise was gone.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
