18th June 2012
Posts: 10 Sportster/Buell Model: XLCH Sportster/Buell Year: 1972 Other Motorcycle Model: Kawasaki KZ400 Cafe Other Motorcycle Year: 1975
New Guy Here... (mod to front drum brake to beef it up?)
Hi everyone. I'm a longtime rider (25+ years) but just recently bought my first HD (a 72 XLCH/photos to follow). I'm loving it EXCEPT that front drum brake is damned scary! I thought the right-side shift was going to be an issue, but I figured that out pretty quickly. So, here is my question:
Is there any mod I can do to that front drum to beef it up? Or do I just have to suck it up and plan my stops a half mile in advance?
Thanks in advance for your expert opinion. Seems like a great bunch of people here.
18th June 2012
Posts: 2,243 Sportster/Buell Model: Nightster Sportster/Buell Year: 2009
Welcome from Norcal.....Flash
Trying to balance being an "unknown quantity" and a "known associate" ....it's tuff
2009 XL1200N Nightster...SE Heavy Breather>SE SP black slip-ons w/modified Cycle Shack baffles>Speedway Instruments MicroTach+>Super Brace>Kriss headlight modulator. Willie G skulls @ gas cap,derby and timer>Misc. black nut and bolt covers>Garage Leathers solo bag>Mustang Vintage 12.5" solo seat>LED taillights>10.75" RK air shocks>G2 Ergonomics Quick Turn throttle>Power Commander V>Giving 10R12 plugs a try.
76 HP X 79 TQ
Ol' Dirtbeard of the Cracked Craniums MC
18th June 2012
Posts: 784 Sportster/Buell Model: 883L Sportster/Buell Year: 2006
Welcome from SW Mississippi. Uh, you can do what I used to do with my old 69 FLH back when I got it in 1976. It had front drum brakes: I'd start slowing down way ahead of time and dragging my feet. That helped, until I rebuilt the entire bike in the late eighties and put a disk brake set up on the front.
18th June 2012
Jester Mafia
Posts: 8,859 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 Other Motorcycle Year: 2012
Welcome from SoCal !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
18th June 2012
Posts: 1,351 Sportster/Buell Model: 1200r Sportster/Buell Year: 2004
Welcome from New Mexico
18th June 2012
Posts: 567 Sportster/Buell Model: XLH1200c Sportster/Buell Year: 2002
Welcome from Portland Or.
18th June 2012
Posts: 4,951 Sportster/Buell Model: Hammer 1250 Hugger Sportster/Buell Year: 1997
Welcome to the forum from SW Pennsylvania.
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
18th June 2012
Posts: 305 Sportster/Buell Model: sportster Sportster/Buell Year: 1972
Welcome to the forum from Pa
18th June 2012
Posts: 73 Sportster/Buell Model: Sportster 883 Sportster/Buell Year: 1987 Other Motorcycle Model: Triumph Bonny till stolen Other Motorcycle Year: 1971
Welcome to the world of Sportsters and the XL Forum.
Since this aint your first rodeo, I assume you aren't running out of lever travel. If you are then you may just need to tighten the cable adjustor. After that, open up the drum and see what's worn. Worn pads, actuator cams or cam slot on the shoes can all reduce brake effectiveness.
With my Triumph conical drums, we could attach rebuild clips to the actuator cams [or was it the cam slot on the brake shoe where it contacts the cam?] to make up for excess wear.
18th June 2012
Posts: 443 Sportster/Buell Model: 1200N Sportster/Buell Year: 2009
Welcome to the Forum!
Dyna bottom mount headlight, RSD Clip Ons, NRHS Hurricane 2" A/C, Hand made Lucite A/C Cover, Screamin' Eagle II Slip ons with BCT Monster Baffles fitted, Whittle Beast Hybrid Shocks-Using the HD 2 up low profile springs, Engine Tuning by me and my TTS.
| Thread Tools |
| Display Modes |
