famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27) |
30th June 2012
Posts: 9,999 Sportster/Buell Model: 1998 S= Superior Model Sportster/Buell Year: 1998
There is a plate mounted to the frame and then the 1/2 X 1/2 mount comes off from the plate and the female foot peg mounts to that
they mount to the frame plate like the highway pegs do
Sportsters Rule !
1st July 2012
Posts: 234 Other Motorcycle Model: HERITAGE SOFT TAIL Other Motorcycle Year: 88
Very juice even with pics wow lol
1st July 2012
Posts: 1,544 Sportster/Buell Model: XL1200C Sportster/Buell Year: 1998 Sportster/Buell Model #2: 883/1200 Hugger Sportster/Buell Year #2: 1992 Other Motorcycle Model: Bonneville Other Motorcycle Year: 1971
Originally Posted by dr.feltersnatch
i must be mis understanding how it is actually attaching to the bike. i see how the peg attaces to the extension but not how the extension attaches to the bike
Threaded hole on the motor mount side. Like a passenger peg extension, but threaded so a bolt goes through the motor mount and into the extension. Not hard to make a longer extension with square bar, dril/tap, and bent to shape with heat. The issue will be the amount of flex you will get the farther they extend away from the mount. My friend had that set and bent the shift side when he hit a pig pot hole in the road and slammed his weight against them. We changed them to the style I have. Kinda like the stock HD parts, but aftermarket. i never investigated if we could bridge the 2 sides together with all thread and a pipe or if I could drill them deeper and use a longer bolt to increase its rigidity. A larger diameter bar and larger bolt would work, and you cut/grind/machine down the peg perch area to mount the peg.
Life may begin at 30, but it really interesting around 150!
1st July 2012
Posts: 15,419 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
I've seen adapter's somewhere. I'll look around and see what I can find.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
1st July 2012
I tried to add a spacer between the frame plate to the 1/2 X 1/2 mount but could not get long enough hardened bolts ! that's why I am looking for Longer Foot pegs ! now this is what the guy at work made for me it's too long and the wrong diameter
1st July 2012
you could do the same thing with a piece of pipe though. That would allow you to determine the length you want. And then cover it with a bit of leather, groove it with a grinder for o rings....
1st July 2012
I will come up with some thing
2nd July 2012
Posts: 810 Sportster/Buell Model: xl883c Sportster/Buell Year: 2007 Other Motorcycle Model: KZ 400 Other Motorcycle Year: 1975
how about something like these?
http://www.ebay.com/itm/BRAND-NEW-HA...364963&vxp=mtr
just cut them down and drill them to accept your pegs?
2007 XL 883 C>>>>76c.i. NRHS, 1200 heads, Powervision tuner, Screaming Eagle AC, Sampson BG3 pipes & tons o' other stuff
2nd July 2012
Originally Posted by aemsee
I will look into them and see if I can make them work thanks bud
Sent from my Polaroid Tablet using Tapatalk 2
2nd July 2012
I think its JP Cycles that has what your looking for. They're $40 a pair:
Part no: 530-137 - 1.5" Footpeg Extension http://www.jpcycles.com/product/530-137
Part no: 530-138 - 2.5" Footpeg Extension http://www.jpcycles.com/product/530-138
| Thread Tools |
| Display Modes |
