Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > EFI Sportster Motorcycle Talk (2007 and up)
famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
NHRS Performance
Get Lowered
Marks Moto Gear
Old 30th June 2012
Mfoster526's Avatar
Mfoster526 Mfoster526 is offline
Mfoster526 is an unknown quantity at this point
I failed to mention its a 2008 1200 XLC. If that helps.
Old 30th June 2012
Cosmo Kramer's Avatar
Ohm's Mafia
Sportster/Buell Model: 1200N
Cosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant futureCosmo Kramer has a brilliant future
Do you have a multimeter or test light? Since you have made so many changes we need to start tracing power to make sure everything is working correctly or try to find what was wired wrong / pinched / etc etc.
Have you checked for spark at the spark plugs?
Cosmo
Old 30th June 2012
Mfoster526's Avatar
I switched back to the stock starter switch & wired it up turned the key & now I hear the fuel pump engage. I am going to solder the connection & try to find a nice place on the frame to hide it away. I will keep you posted. I have checked for spark & that's positive. I also have a light to try to trace back each spot that has current.
Old 30th June 2012
Mfoster526's Avatar
Still no dice! I think I bit off more then I could chew in attempting switch relocation...
Old 1st July 2012
Ohm's Mafia
You still looking for help MF? What exactly is happening? Is the fuel pump running? Does the bike's engine turn over? What lights are you getting with the key in accessory and on?
Old 1st July 2012
Loony's Avatar
Loony Loony is online now
Loony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to beholdLoony is a splendid one to behold
Do pre rubber mount sportster suffer with these battery terminals coming loose?
Regards,
Loony
2004 XL1200 Roadster - TC88A Jester 4 (Thanks Rico) - EZ IMS - CVP Jet Needle - 46 pilot - 180 Main - K&N Airfilter - SEII Slipons.
I was born not knowing and have had only a little time to change that here and there.
Richard Feynman, Letter to Armando Garcia J, December 11, 1985
US educator & physicist (1918 - 1988)
Please take a look at this amazing task and worthy cause:
Christian Nock Around Britain - Coastline Walk To highlight the plight of homelessness of ex-soldiers.
Tools needed for the Job
1 X Mk1 British Army Infantry Soldier, a Target and some time.
http://www.christianaroundbritain.co.uk/
http://www.bmycharity.com/ChristianNock
https://www.facebook.com/christian.britain.3?fref=ts
Old 1st July 2012
Mfoster526's Avatar
Yes any help would be appreciated. When to accessory no lights @ all, then I turn the key to ignition I hear the fuel pump cycle, all lights are activated, headlight brake light remaining turn signals. Then when I go to turn the bike on I hit the start switch & nothing.
The bike has been sitting for about a month without being ridden since I have been working on it. Could it be a lack of juice from the battery? Also, I rewired the switch run/off I made sure was grey wire & white/black. Start button is black/red & white black.
Old 1st July 2012
Ohm's Mafia
Yeah, first step is to make sure you have a fully charged battery. Otherwise we could be chasing things that ultimately lead to not enough juice coming out of the battery.
FYI...when the key is in the accessory position you should have turn signals and brake lights....along with the horn at least with the stock wiring.
Old 1st July 2012
Mfoster526's Avatar
Up until yesterday even the headlight was on when in the accessory position & now nothing. I am going to pull the battery & take it down to get tested since I do not have the capability to do it here. I will keep you posted.
Old 1st July 2012
Ohm's Mafia
Yeah....headlight shouldn't be on until the ignition is switched to "on".
