30th June 2012
Posts: 79 Sportster/Buell Model: XL1200N Nightster Sportster/Buell Year: 2009
Wife dropped bike, now the front cylinder taps and smokes
2009 Nightster...
So my wife decided to put her foot down on the downhill side when stopping at a stop sign. She was completely stopped. She dropped the bike on the right side. Now the bike taps/clicks/pings (whatever you wanna call it) on the front cylinder and smokes somewhat bad until hot.
I am 99% positive the clicking/taping is not normal. I have replaced the exhaust gaskets...
What kind of damage do you think she could have done?
Just made the first payment
Any help/advice would be great.
30th June 2012
Posts: 2,881 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2002
Did the air filter take a hit. Maybe you have an intake leak.
2002 XL1200C (originally)
Stage II Buel XB Heads, Andrews N4 Cams, Mikuni HSR42 Carb, Forcewinder Air Filter with Float bowl vent mod, S&S Roller Rockers, Jim's Powerglide Lifters, Thunderheader Exhaust, Daytona Twin Tech SIngle Fire Ignition, Crankvents.
Max Power=85.47
Max Torque=81.84
Flow Bench Results
30th June 2012
Posts: 1,434 Sportster/Buell Model: 1200c Sportster/Buell Year: 08 Sportster/Buell Model #2: Xlh Sportster/Buell Year #2: 77
first off welcome to the forum! is there any visible damage? if so start there. how long was it on its side? was she able to pick it right back up or did it lay there for a few minutes? was it still running while on the ground or did it get shut right off? the reason i ask is if it sat on its side for a bit it could have got some extra oil in the cyl causing smoking. not a big deal. also what color is the smoke? black = too much fuel, blueish= burning oil.
"A man dies when he does not stand up for what he knows is right"
30th June 2012
Getting Hammered!
Posts: 5,078 Sportster/Buell Model: 883L (sorta) Sportster/Buell Year: 2007 Sportster/Buell Model #2: 1200R Sportster/Buell Year #2: 2007
Was there any visible damage to the engine? Besides exhaust or intake seals/gaskets I really can't think of anything. I've dropped my 2007 way more times then I care to admit and never had any issue (besides the scratches  ).
Screw Loose Dan
Pegs down for BryanEOD...you'll be missed but not forgotten.
Thanks to all those that serve and especially all those that have given all.
"Life should be lived"
30th June 2012
''Under control''
Posts: 2,983 Sportster/Buell Model: xl 883c<1212 Sportster/Buell Year: 2005
Just possibly bent a push rod? look at the push rod tube, look for damage there. just a drop shouldn't( but could) make a engine knock. If the pushrod got out of whack it may cause smoking and knocking. future advice, she should put BOTH her feet down at every stop. one foot is for a scooter. Two feet is for a full motorcycle. But back to the problem.
Intake leak, oil seeping out of the head, base or rocker cover. For pinging to happen there has to be damage to the engine internally. But my first guess is a problem with push rods.
With all the dumb-asses in the world, you'd think a smart-ass would be shown more appreciation. - Biker Dude Dref
hp = (torque x rpm) / 5252
I will work till the zombies come, then I play- Char_dHin
Amidst the mists and coldest frosts,
With stoutest wrists and loudest boasts,
He thrusts his fists against the posts,
And still insists he sees the ghosts.
Zombie Leg Humpers M.C.
http://xlforum.net/vbportal/forums/group.php?groupid=90
30th June 2012
Posts: 444 Sportster/Buell Model: 883 Sportster/Buell Year: 2004
The 09 has the tilt sensor that should have shut it off very very quickly as well, to help prevent engine damage
30th June 2012
Posts: 137 Sportster/Buell Model: XL Sportster/Buell Year: 04
Odd, I full on high sided with bike sliding on right side off into ditch! After I got everything back together engine fired right up, and I never touched anything internal. Maybe something was about to let go and the drop finished it? Wait it stops smoking after hot? Does the noise stop also? Guess I'm with chardhin until further investigation.
I'm 5'8" 165 and my names not Rick! Go figure!
30th June 2012
Posts: 23,736 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
Over the years i have had 60' and 150' slides along the pavement/gravel, plus too many driveway drops - never an engine problem. Always just pick it up, dust it off, straighten some bent parts, ride home.
Try this procedure from the IronHead forum Stickys to isolate the source of the sound ...
IronHead Noise
http://xlforum.net/vbportal/forums/s...d.php?t=832376
30th June 2012
Posts: 92 Sportster/Buell Model: XL1200L Sportster/Buell Year: 2009
My wife dropped my 09 low on the right. She applied brakes without clutch and stalled. It went over with help. Didn't have any problems. I was there and lifted it quickly. I would be curious how long it was over. My 09 has a tilt switch in it. I stalled taking off in a dip, my foot hit just as the exhaust touched and it posted a tilt on the speedo. Check the spark plug for fouling. If she let it lay there and some oil got in the cylinder and you ran it.
1st July 2012
Posts: 2,375 Sportster/Buell Model: XL883 Sportster/Buell Year: 2008 Sportster/Buell Model #2: XL1000 Sportster/Buell Year #2: 1975 Other Motorcycle Model: Aermacchi Harley SX175 Other Motorcycle Year: 1975
Sounds like some oil got in the cylinder, Dark Smoke, and Pinging could both be caused by excess oil in the combustion chamber. Pull the plug and take a look.
| Thread Tools |
| Display Modes |
