famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27) |
5th July 2012
Posts: 9,999 Sportster/Buell Model: 1998 S= Superior Model Sportster/Buell Year: 1998
w cams can you tell me about them
I have a 1998 S and I am told it has W cams and dual plugged heads what does this do for proformance and how are these cams different
Sportsters Rule !
5th July 2012
A Million Facts & Figures
Posts: 5,899 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
"W" cams have the intake timing pulled way back from the standard "D" cams, in other words it opens the intake valve sooner and it closes it sooner. Closing it sooner builds more cylinder pressure.
On top of that, the "S" heads on your bike, also known as "Lightning" heads, have smaller combustion chambers than the standard 1200 hemi heads of that era; as such, the bike has more compression.
The idea of the dual plugging was to allow this combination, i.e. the early close timing of the "W" cams together with the higher compression from the "S" heads, to work without causing detonation. Dual plugs result in a faster burn that can be initiated later, and it tends to reduce detonation better.
On the intake open side, the "W" cams have more "overlap", which basically means there's a larger window of time at the tail end of the exhaust stroke and the front end of the intake stroke where both valves are open. Overlap basically connects the intake to the exhaust, and therefore gives the pipe more control of the cylinder fill. It essentially gives the pipe more control over the powerband, and makes it's selection that much more critical.
5th July 2012
Thank you ! now I have a better understanding of what I have ! I am a Drag Pipe nut but have removed them and went with a stock exhaust system with SEIIs mufflers the bike seems to have more torque down low and my butt dyno says it's more throttle responsive in the mid range ! and 1 other Question with this motor does it have the same HP / Torque ratings as all the other 1200 motors ???
5th July 2012
There are lots of 1200S owners on the site who can probably answer that question definitively, but to my aging memory, I seem to recall Harley not making any horsepower claims back then, but claiming the 1200S made more torque than the standard 1200. Hopefully a 1200S expert will chime in soon.
But of course, horsepower is torque times rpm, which means that at any given rpm, more torque means more power.
5th July 2012
Thank you ! I appreciate your help and answers !
5th July 2012
Posts: 6,946 Sportster/Buell Model: XL1250S Sportster/Buell Year: 1998
Click here for a link to an early review of the '98 1200S.
Basically, with the engine mods you get little difference until Harley taxes are paid, after which you can expect a bit more grunt than you'd get from other models from that era.
As Aaron mentioned, it's not surprising that you're getting better results with SE slip-ons than with drag pipes.
5th July 2012
thank you for the info and the link ! sooner or later I am going to change the air box and re jet the carb ! and I do love the low rumble of the new exhaust
5th July 2012
Amateur Hour
Posts: 2,971 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
A good aftermarket air cleaner would help out a lot with your slip ons. Another cheap idea would be to put a 27 tooth front pulley on instead of the 29. 27 would be 883 factory pulley. It would gear the bike down a touch. Just a thought. Good luck
5th July 2012
thanks ! but I don't think I am going to change the pulley just the air box ! I am not in a hurry to go fast any more ! now to find a good air box I think I will go with the ness big sucker depending on the price
5th July 2012
Posts: 4,669 Sportster/Buell Model: Hammer 1250 Hugger Sportster/Buell Year: 1997
Are you running a stock air cleaner inside the stock box? If so, I might be able to help.
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
| Thread Tools |
| Display Modes |
