The Sportster and Buell Motorcycle Forum Figure Machine
Zippers Performance
Dead Creek Cycles
Old 10th July 2012
FearlessFrisbee's Avatar
FearlessFrisbee FearlessFrisbee is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1957
Sportster/Buell Model #2: XLS
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Indian Scout 741
Other Motorcycle Year: 1941
FearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really nice
+1 on cleaning very well. But then, I'd use baby powder on the area to see where it really may be leaking from.
I have found leaks completly on the other side of a cylinder from where I thought it was leaking from.
The powder doesn't lie. And no jokes about the wet spot please.
Old 10th July 2012
Robicycle's Avatar
Robicycle Robicycle is offline
Robicycle will become famous soon enoughRobicycle will become famous soon enoughRobicycle will become famous soon enoughRobicycle will become famous soon enoughRobicycle will become famous soon enoughRobicycle will become famous soon enoughRobicycle will become famous soon enough
That's a great idea, I will have to remember that in case I need to locate a small crack/leak.
Old 10th July 2012
78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about78ironhead has a spectacular aura about
Clean it up real good with some solvent or brake kleen, start it up and look at it with a magnifying glass. You can get one at the drug store or hardware store. My 79 has that crack looking casting there too.
Heres at it and to it and to it again, if you don't do it when you get to it, heres by God hopen you never get to it to do it again.
Old 10th July 2012
RIDERED67's Avatar
RIDERED67 RIDERED67 is offline
Sportster/Buell Year: 1967
Sportster/Buell Model #2: Forty Eight
Sportster/Buell Year #2: 2012
Other Motorcycle Model: Which one?
RIDERED67 is on a distinguished roadRIDERED67 is on a distinguished road
Man you just bought the bike, it looks clean and im sure the last thing you want to do is tear it apart right now. If it was mine and the oil was leaking from that crack i would do a quick fix to stop the oil then tear it down over the winter. I dont like to half ass anything but ive come to realize that sometimes a simple fix will get the job done.
Oh and make sure you get a support bracket on your carb before it falls off
Old 10th July 2012
Originally Posted by 83IRONXLX View Post
... what is a JB weld? ...
JB Weld is a two part epoxy glue product that contains steel particles. Buy at Canadian Tire, Princess Auto, Harbor freight, auto supply, etc.
Old 10th July 2012
Chipper442's Avatar
Chipper442 Chipper442 is offline
Sportster/Buell Model: Xl883C
Other Motorcycle Model: 12+ Honda dirt bikes
Other Motorcycle Year: Many
Chipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of lightChipper442 is a glorious beacon of light
If it is a crack,I would recommend staying away from the "quick fixes". JB Weld,will just run down into the case and get on whatever is underneath it,same with green Loctite.
As a welder,I wouldn't touch that job unless the cases were split,and empty,even with a tig welder,you stand the chance of contacting rotating parts with the weld bead. Just my two cents,but I would tear it down now,and do it correctly the first time. You might even find a case half,for less money than what a repair to the broken one would be.....
Old 10th July 2012
sunchild2071's Avatar
sunchild2071 sunchild2071 is offline
Sportster/Buell Year: 1968
Sportster/Buell Model #2: XLH1200
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Chopped Shovel
Other Motorcycle Year: 1978
sunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to beholdsunchild2071 is a splendid one to behold
Default Brakekleen
It bears mention, for the danger level potential.
If you will be cleaning that with brakekleen, and take it down in the future for welding, TELL your welder what you used for cleaning. The welding process, combined with the brakekleen can cause a deadly gas, toxic at under 5 ppm.
There are many slovents for cleaning, brakekleen should be reserved for what it is meant to clean. If you do use it, and wind up welding further down the road, be sure to mention it to the welder.
As I noted in my first reply I might be somewhat alarmist to the nature of your problem, but if it is a crack, some thing caused it. And there may be more, hence my advice of teardown. I tend to like doing things once, properly, and not looking back.
There are other good, temporary, solutions here by some very knowlegeable people. Follow the path you think is best.
Disclaimer: I'm not the guru on this stuff, be sure to seek further opinion/knowledge.
Old 10th July 2012
gungatim's Avatar
gungatim gungatim is offline
Sportster/Buell Year: 79
Other Motorcycle Model: Yamaha TX500
Other Motorcycle Year: 74
gungatim will become famous soon enoughgungatim will become famous soon enoughgungatim will become famous soon enoughgungatim will become famous soon enoughgungatim will become famous soon enoughgungatim will become famous soon enoughgungatim will become famous soon enough
Hard to believe it is cracked there, as others said, there is a casting line there (my '79 has it too), and shouldn't be so much oil pressure there that it is flowing at a "pretty steady trickle". I would heed the advice to check very carefully around the pushrods and lifter block to see where it is really coming from. Sometimes on a house with a roof leak, water follows a very odd path and a leak in one spot often comes from somewhere entirely different. Your bike may be the same. Maybe pull the lifter block and pushrod tubs themselves for an inspection. try and get one of those little mirrors on an extendable antennae (inspection mirror?) and look behind the pushrod tube and lifter area to ge a better look.
Good luck...
Nolite Te Bastardes Carborundorum!
Old 10th July 2012
Originally Posted by gungatim View Post
hard to believe it is cracked there, as others said, there is a casting line there (my '79 has it too), and shouldn't be so much oil pressure there that it is flowing at a "pretty steady trickle". I would heed the advice to check very carefully around the pushrods and lifter block to see where it is really coming from. Sometimes on a house with a roof leak, water follows a very odd path and a leak in one spot often comes from somewhere entirely different. Your bike may be the same. Maybe pull the lifter block and pushrod tubs themselves for an inspection. Try and get one of those little mirrors on an extendable antennae (inspection mirror?) and look behind the pushrod tube and lifter area to ge a better look.
Good luck...
+1
Old 11th July 2012
83IRONXLX 83IRONXLX is offline
Sportster/Buell Model: ironhead xlx
83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light83IRONXLX is a glorious beacon of light
Default things are looking up...
OK first of all i want to say thank you to every single person on here who tried to help me out,you guys rock....Yes i was wrong. I ran the bike again and really looked close.
As many of you suspected...
There is a tiny leak coming from one of the two skinny rods inbetween the "pushrods". I searched all over to find what they are called but cant find it.....I now know what a pushrod is though!
The "skinny rod" on the left has a nut at the bottom of it and the oil is coming up from where the rod goes into it...probably a rubber seal I am hoping?
The oil trickles out and down the back and when it gets to that mark in the casting that looks like a crack it kind of sticks to it... looking like it is a crack with a leak. (thats my excuse and i am sticking with it)
I am so damn happy right now cause i am pretty sure this isnt a big problem now right?
What are these rods called and what do they do?
I tried to tighten it with a wrench but it didnt seem to help...any ideas?
The amount of oil pooled in this picture took about 20 seconds of engine idling.
Thanks again everybody, I am going to learn a lot here and I am looking forward to getting my manual so I dont have to be a huge pain in the ass..
x
