16th July 2012
Posts: 1,539 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Originally Posted by 1250IRON
Look real close at the bottom of each cylinder on the left side of bike if you were sitting on it.
most cylinder upgrades like hammer and NRHS put their mark here. i'm not sure if the screaming eagle has a mark here also.
to me they do look like replacement cylinders due to the fact that the heat fins do not line up with the head fins. i believe on my iron they did on the stock cylinders. could be wrong though.
Hammer Performance has the mark behind the lifter block, hard to see the hammer. Screaming eagle has just the HD, they are regular 1200 cylinder, the head are deck 50 mil.
16th July 2012
Posts: 46 Sportster/Buell Model: 883 Sportster/Buell Year: 1999
I would wonder that the conversion hasn't been done. The air intake looks stock, and the ignition looks stock. I would imagine that most people spending the coin on a conversion would also upgrade those two items. Maybe I'm wrong, but normally you see something different done there.
Have you ridden a 1200 before? They run a bit better than most people think, and when I first rode my 883 it took me a few miles to realize it. The seller thought I knew it was an 883, I thought it was a 1200. Explained why the price was low.
16th July 2012
Posts: 430 Sportster/Buell Year: 1987
last oct. I bought a 95 883, from a mechanic who told me the previos owners did something to the heads to make it a 1200..I knew he was full of it , but bought the bike anyway,,not power crazy myself at 53, and it only has like 8k on it anyway, think it was bought and rode a year or 2 and then sat for 15 years as the tires were dry rotted, the paint is good but faded..I had to put forwards on it , to make it fit me,, I'm happy like it is for now..Rog
16th July 2012
Senior Master Bike Builder
Posts: 2,132 Sportster/Buell Model: XL1200N (Sold) Sportster/Buell Year: 2009 Other Motorcycle Model: ZX6R Other Motorcycle Year: 2012
If you have to play a guessing game, just move on. There are plenty others out there. Just for the fact it has a different tank for an unknown reason would make me a skeptic. Was the first one damaged? The R model had the same size tank. Just my 2 cents.
16th July 2012
Posts: 620 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2008
The seller should produce paperwork for the 1200 conversion,,parts list n such.
and who and where did the work,,
If not you may be paying a 1200 price for an 883,,,,,
Hope the conversion was done right,,
Personally,,Me,,,I would only buy used if the engine was never opened...
He punched It out to a 1200 he says,,,that means he punches It hard
I'd pass
2008 XL1200R
16th July 2012
I'd pass.
Unless your In love with the bike,,then Its too late.
Go on and buy yer hearts desire,,
Ya only live once...
17th July 2012
Posts: 1,033 Sportster/Buell Model: Sportster XLH1100 Sportster/Buell Year: 1986 Other Motorcycle Model: Rupp Roadster Other Motorcycle Year: 1971
If I recall correctly, if they used OEM cylinders for the upgrade, a "1200" will be embossed into the front, lower right side corner with numbers running vertically. Sort of at the oil filter mount part of the cam cover and almost behind the pushrod. Hard to see.......
Although.... I'm not sure they are still doing that......
If it says 883, then it was either bored out to 1200 or is still a 883.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
17th July 2012
SHADE TREE MECHANIC
Posts: 230 Sportster/Buell Model: XL883R Sportster/Buell Year: 2003 Other Motorcycle Model: WR250F Other Motorcycle Year: 2008
i have been trying to find this for a while check out this link...........
http://xlforum.net/vbportal/forums/s...200+conversion
03 883R NRHS 1250 stg 3 04xl1200r heads 15 deg dome SE.575 Daytona twin tec lsr 2-1 works suspension storz rear sets
17th July 2012
Posts: 369 Sportster/Buell Model: 883 hugger/1125R Sportster/Buell Year: 1/8 Sportster/Buell Model #2: XLH 900 maybe... Sportster/Buell Year #2: 1968
Originally Posted by Vrenlos
Does anyone else know any tell-tale signs of the conversion?
who cares if it is a 883 or 1200? regardless of what it is, it is a nice looking bike, and once you get it, call up Dan @ NRHS (or @ Hammer, your choice... apparently everyone is named Dan?) and get a 1250 kit, and laugh at all those silly people with their little 1200's...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
18th July 2012
Posts: 12 Sportster/Buell Model: 883R Sportster/Buell Year: 2007
Once again guys, thanks for all of the input - that diagonal measurement idea is genius. However, after I started asking questions about the conversion and showed that I had done my homework, he miraculously went from trying to convince me to buy the bike to "keeping it for himself". I'm sure I'll see it listed back on craigslist in a day or two.
On the incredibly more positive end of things, I found an 04 1200R that's for sale right around the corner from someone I know for only a small amount of investment more. Oh and did I mention it's got the pipes I wanted, a few pairs of bars/seats/etc., and was tuned by another guy I know (and trust)? Woo!
| Thread Tools |
| Display Modes |
