Go Back   The Sportster and Buell Motorcycle Forum > GENERAL AREA > Motorcycle Camping
Motorcycle Camping When, What, and When
Progressive Suspension
Licks Cycles
Old 18th July 2012
Other Motorcycle Model: XLH
Other Motorcycle Year: 1972
sportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant futuresportsterpaul has a brilliant future
Peter: My small "Wolfman" Beta bag that I run on the stock rack carries spare parts, service manual, shaving kit, tent sleeping pad, sleeping bag with room to spare. tank bag carries rain gear,(yeah, someday I'll have some of that nice "Stich" stuff), extra glasses, small amount of gear and visor/windscreen cleaner. Another small bag straps on top of the beata with extra clothing. If you're coming across check out Greg's homemade platform.
I.B.A.#26543, Old age and treachery ALWAYS overcome youth and skill! ******** Growing old-Mandatory/ Growing up-optional. Men do not quit playing because they get old, they grow old because they quit playing
Old 18th July 2012
paralegalpete's Avatar
paralegalpete paralegalpete is offline
paralegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant futureparalegalpete has a brilliant future
Couple thoughts on the Higgy platform, I assume it's aluminum, thickness?
Any thoughts on going bigger/ wider with it?
Old 18th July 2012
Screw Loose Dan's Avatar
Screw Loose Dan Screw Loose Dan is online now
Getting Hammered!
Sportster/Buell Model: 883L (sorta)
Screw Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant futureScrew Loose Dan has a brilliant future
Over in Brad's thread on the topic, he mentions 3/16" thickness for the aluminum. I was thinking mine was 1/4", but it's been a long time, so it's probably 3/16".
The issue with going wider, it depends on your saddlebags (if equipped). The width of mine gets in the way as it is. No saddle bags? Probably not an issue to go a bit wider. And I wouldn't want to make it much longer. Depending on how you distribute the weight, it hangs off the back enough, IMO.
Screw Loose Dan
Pegs down for BryanEOD...you'll be missed but not forgotten.
Thanks to all those that serve and especially all those that have given all.
"Life should be lived"
Old 18th July 2012
Deacon Dan Deacon Dan is offline
Deacon Dan is an unknown quantity at this point
Be careful of too much weight to far back giving you the wooblys.
Only the first good shot counts!
Old 20th July 2012
I ordered 3/16 alum textured plate, a little softer than the 6061 and probably easier to drill.
I went a couple of inches wider my bags are soft, and worst case are quick detach.
Old 20th July 2012
Getting Hammered!
Sounds good Pete! Let us know how you make out. I drilled the aluminium with one of those step bits and it wasn't all that bad. Even thicker aluminium like that is still pretty easy to work with. I used some bed liner to try to coat mine...which really hasn't worked all that well as much of it is flaking off.
Old 22nd July 2012
Default Got the plate drilled and finished
I ordered the rack from HD should be here on tuesday
I drilled the holes in a a little different pattern
Old 22nd July 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Sportster/Buell Model: Hammer 1250 Hugger
Gcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant futureGcram399 has a brilliant future
I drilled the holes in a a little different pattern.
You can't go wrong with aluminum diamond plate. It's going to look good and work even better.
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
Old 22nd July 2012
PistolPete PistolPete is offline
PistolPete is an unknown quantity at this point
ScrewLoose, how did you attach those two side cases to the bike (the pelicans, not the saddlebags)? is there some extra brackets under there?
2009 1200N - currently parked 7000 miles away
Old 22nd July 2012
Getting Hammered!
Paralegal Pete - Looking good! Honestly, I've never used all the holes in mine, but it's easy/cheap to drill them. Are you bolting this to you current rack or getting the solo rack like Brad and I have?
Pistol Pete - The side case pelicans are attached with EasyBrackets, so they mount/unmount very quickly and easily.
