22nd July 2012
Posts: 444 Sportster/Buell Model: 883 Sportster/Buell Year: 2004
road king shock install(harley part numbers)
Rather then mess around, rather just get the parts from the dealer.
who has the air hose, and valve part numbers?
thanks
mikey
22nd July 2012
Posts: 399 Sportster/Buell Model: Custom Sportster/Buell Year: 05
Just got the part numbers the other day
54320-97 Push In fitting, 5/32in (2) $14.56
54536-09 Valve and Airline Asy, RR S (1) $34.50
Don't care what you ride as long as you ride!
22nd July 2012
nice!
thank you
22nd July 2012
Jester Mafia
Posts: 605 Sportster/Buell Model: 1200C Sportster/Buell Year: 2006
Save yourself the money if you can. Installing air line just to pump up both shocks from one schrader valve is a PITA and not at all necessary – unless your shocks are covered up by saddlebags. Before I got saddlebags that blocked the schrader valves, I just adjusted each shock separately via an inexpensive brass schrader valve I found at NAPA. Takes an extra 10 seconds to do each shock separately. You can probably find the valves at ACE, too. Once I mounted the saddlebags, filling them up separately was no longer convenient. I bought an air shock kit at AutoZone with black plastic air line and got brass fittings at ACE. If you go this route, get extra ferrules and tighten the fittings only a quarter turn at a time until they hold air without crushing the plastic line. I ended up over tightening them a few times because it's very easy to crush plastic line with brass fittings. Worse, I jacked up the threads on the plastic 2-into-1 schrader valve and ended up buying another kit from AutoZone. LuxBlue bought the HD kit and posted a detailed thread on the installation in the suspension stickies ("Road King Shock Install Pictures"). The HD kit is pricey, but it's probably worth it for ease of installation and durability. I'm always worrying that I'll mess up the plastic threads on the valve again. I probably saved a little money with the route I took, and the setup works fine for now. But if I ever have to redo the installation, I'll buy the HD kit because it looks more durable in LuxBlue's pictorial than what I bought at AutoZone.
22nd July 2012
hmm, maybe i will go that route for now then.
what size is the valve just so i know?
I still need to get a lowering block for them, as they are 13s, and my current setup is around 11.5-12
22nd July 2012
Jester Mafia
I believe the valves you need are 1/8 NPT and cost around $2.50 each.
22nd July 2012
Posts: 1,836 Sportster/Buell Model: XL1200c Sportster/Buell Year: 2006
Use the search at the bottom of the page for AIR SHOCK PART NUMBERS. Air lines are easy. $8-10 at autoparts store for a generic air shock hose kit, then at ACE get 1/8 NPT compression fittings. Use teflon tape and when done the old soapy water test. Done for under $12
"A democracy cannot exist as a permanent form of government. It can only exist until the voters discover that they can vote themselves largesse from the public treasury. From that moment on, the majority always votes for the candidates promising the most benefits from the public treasury with the result that a democracy always collapses over loose fiscal policy, always followed by a dictatorship.
Alexander Fraser Tytler
22nd July 2012
Posts: 4,588 Sportster/Buell Model: Hammer 1250 Hugger Sportster/Buell Year: 1997
+1 Great advice. Nothing like having 1 fill fitting. It's the only way to know for sure that both shocks have the same exact air pressure.
Support the forum because the
George
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Head Treatment w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Basanni Road Rage 2-1 Exhaust with a 4" Performance Machine Billet Tip.
22nd July 2012
Posts: 158 Sportster/Buell Model: XL1200C Anniversary Sportster/Buell Year: 2003 Other Motorcycle Model: Honda XR400R Other Motorcycle Year: 2001
From the looks of it you got the shocks, have fun with them, good luck on the one air house set up. Love the bars, got 'em on and they are perfect. I don't run saddle bags so
filling each of mine is not that big of an issue.
Thanks again good trade.
SA, a General BA, who doesn't like any BS.
2003 XL1200C Anniversary Edition.
Chromed up from the Factory.
22nd July 2012
Jester Mafia
I rode almost a year with separate schrader valves and never had any problems. Sure, it's nice to know that both shocks are filled to exactly the same pressure, but it can't be that critical. I have a 0-30 psi pump with an easily readable gauge and used to check them at least once a week. Never had any leak down. I can't tell any difference in performance now that they're linked to one fill fitting.
| Thread Tools |
| Display Modes |
