4th August 2012
Posts: 487 Sportster/Buell Model: XR 750 Sportster/Buell Year: 1972 Sportster/Buell Model #2: RR 250 Sportster/Buell Year #2: 1976
Originally Posted by DirtyCory
how accurate is the caliper gonna be for this? wouldnt it be better to use an inside mic on something like that?
Telescoping bore gages (some people call them snap gages) ... inside mics are not that easy to use or accurate.
You use them with regular micrometers.
4th August 2012
Senior Bike Builder
Posts: 1,913 Sportster/Buell Model: xlh convert to xlch Sportster/Buell Year: 1978 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1972
cool thanks barefoot. im still a dummy i guess, them are what i thought was an inside mic....lol....
If your gonna do something, do it right!
4th August 2012
Nah, not a dummy, can't know everything ... there are several kinds of inside mics.
For small stuff there's a kind with blades that looks similar to verniers. As you screw the thimble the blades move out. They go up to about two inches but aren't really as accurate as you'd expect.
Then for big stuff there are tubular-looking things that extend as you turn a thimble, kind of like a telescoping tubing. They are okay but the hole has to be big enough to fit your hand into. Mostly good for large holes.
The really accurate ones used to be called Intermikes and had three legs. The legs would extend as you screwed the thimble. Those are very accurate, very expensive, and have a short range. They don't go too big, maybe a few inches. Three or four inches max, if my oldtimer's hasn't kicked in.
If you did a lot of internal measuring, Sunnen bore gages are hard to beat. Or were, I haven't bought any in decades.
Overall, for most work the telescoping bore gages are the most accurate and easiest to use, especially for the price.
4th August 2012
Posts: 546 Sportster/Buell Model: XLS roadster Sportster/Buell Year: 1985
Man I love to build sheeet its just satisfying to know you made something useful and that you can show others how. personally I have a full set of inside mics and snap gauges personally I hate both I usually just use a good ol Vernier get er real close and then check with a better digital. unless its verrrryyyy important then I use my standards and a dial bore gauge. most of the gauges and standards I have are made by Starret, Shars, Sunnen,Mitutoyo, Sears, and Central. and I personally would never try to use a cheap knock off to make a precision part. unless i was doing the whole thing with the same single instrument from the initial measuring to the making. just a thought.
Oh and good luck to ya I've done the same thing with the blower casings of a 671 to prevent the blades from damage due to flexing worked great 20 years ago ...
4th August 2012
Posts: 2,087 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974
Rep's to U 4 sharing.Go lite on that personal lubricating juice over the yrs I've found I do better to wait till I'm finished.
Murphy's Law
4th August 2012
Posts: 5,274 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
i,noticed it was,non-alcoholic. i,did look twice though! i,believe seven year's of famine,is a,quote from the bible.
4th August 2012
My bad I wasn't really looking at the beer just digging what he's doing.
4th August 2012
Posts: 172 Sportster/Buell Model: XLH Sportster/Buell Year: '60 Other Motorcycle Model: xs650 Other Motorcycle Year: '72
Cory, you are probably correct. Not the right tool for the job, but I got extra alum. if need be.
Can anyone clarify a few things here:
I've been back through the Dr.'s post a dozen times and I pick up something new every time. I'm just having a hard time making sense of these 2 areas.
Maybe the gap is there to distribute the stress to the case and not the corners of the countershaft boss?
The oil groove stumps me. I thought maybe it was a continuation of the factory groove seen below, but none of the added reinforcement ring pictures have them.
4th August 2012
Master Bike Builder
Posts: 2,021 Sportster/Buell Model: Custom Sputhe XR Sportster/Buell Year: 19** Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1965
Yes I believe the note is to continue oil groove into ring.
You could do it w/ a cutting wheel or file, if no mill, not critical.
He probably just pulled some reinforcement ring photos off the web, thats why the oil groove continuation isnt there, he probably did not work on the case in the photo?
The relief, he mentioned was not to bind the ring on the perpendicular area of case wall and cause additional stress, if I remember correctly.
4th August 2012
way to go 7!
the id relief is so any contraction forces of the original boss (due to the press fit) isnt concentrated at the case boss to case wall junction. this causes stress at the 'corner'.
inviting the whole boss to break off.
the groove is a continueation of the oil groove you pointed out.
as you can see its not totally necessary depending on the height of the ring.
some advice;
make your 1st ring
try to fit it.
your hoping it will slide on "size for size"- that is bore size is the same as boss od.
if its tite back in the lathe, using some sand paper(120 grit) 'polish' the id bigger intill it does just slip on. dont get it jammed on the boss at this point. it can be a bitch to remove. this polishing is a little artsy-fartsy. easy to bell mouth the ring.
compared to the other choice: re-chucking and removing fractions of .001" its way more user friendly.
once you have the ring sized to boss, start construction of the real ring.
using the same measuring tools make new ring .001-.002" smaller than the gage ring. shooting for .001
a little oil will help surface finish when boring.
if parts are hot in lathe they will measure bigger than when at room temp.
| Thread Tools |
| Display Modes |
