15th August 2012
Banned
Posts: 1,613 Sportster/Buell Model: XLH Sportster/Buell Year: 1976
Are you running points? My front cylinder ran forever richer on the front cylinder and I've tried everything to figure it out. I threw a new set of points in and 'centered' the cam lobe better and now they're both even stevens.
15th August 2012
Posts: 178 Sportster/Buell Model: XLH Sportster/Buell Year: 1977
Originally Posted by 2007Low
Does it run ok?
It does until the plug fouls
I'm just a newb with an ironhead, a toolbox, a computer and a FSM.
15th August 2012
Points are newish. I'll look at the cam.
15th August 2012
Posts: 1,451 Sportster/Buell Model: XL1200 Low/TTS/Gronked Sportster/Buell Year: 2007 Sportster/Buell Model #2: XLCH1000 Sportster/Buell Year #2: 1975
How's the compression?
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
15th August 2012
A little while back, I noticed the same issue when I was trying to diagnose a sputtering problem in 3rd-4th, and realized that my idle circuit was way to rich. Once I resolved that issue, the rich plug condition on the front cylinder went away. Just my experience, not sure why it affected the front more than the rear.
15th August 2012
160 on both cylinders ; open throttle; HOT (icing finger tip now) engine
15th August 2012
So.... I adjusted my idle circuit, as best i could as the engine was blistering hot. I counting the gap between the rich and lean engine stalls and set it in the middle. It idled great and and I was able to turn my throttle set screw WAY down.
However....
Now the bike stalls under acceleration.
If I screw it way out (around the 2, 2 1/2) mark bike runs rich, but runs under accelaration.
Before I jump to any conclusions I want to do a more precise adjustment with a cooler engine, but I wanted to give y'all time to think
15th August 2012
Posts: 24,000 Sportster/Buell Model: XLH Sportster/Buell Year: 1978
However....
Now the bike stalls under acceleration ...
Blistering hot is good for setting the idle [unless it prevents you from doing a good job of it]. You had it set correctly for idle so put it back. Next you need to install a larger slow jet to solve the acceleration problem.
16th August 2012
Understood, it was just hard to count screw turns:
1...  ...2...  ...3...  ...4
16th August 2012
My experience with counting turns is that it cannot be done accurately with the carb on the bike. Once i get it running well i take the carb off the bike, put it on my carb stand, check the number of 1/4 turns [using a better sized screwdriver] and write it down. It is always different from what i had thought.
Too hot, too crowded, screwdriver too small, etc. Only accurate off the bike.
| Thread Tools |
| Display Modes |
