Dead Creek Cycles
Dead Creek Cycles
Licks Holiday
Figure Machine
engine noise
Old 18th June 2009
mandaltby's Avatar
mandaltby mandaltby is offline
Sportster/Buell Model: 82 xls 1000
Sportster/Buell Year: 1982
mandaltby is on a distinguished roadmandaltby is on a distinguished roadmandaltby is on a distinguished road
Default Engine noise??
i get a ticking noise when im riding but only when on the throttle, ive put it down to either valves or tapped adjustment. It goes in time with the throttle, but doesnt sound like a tick when stationary, or when I pass a certain RPM. Kind of in Mid range.
sporties just make a bit of noise and ive come to accept it as character!!!
but Id like to see if I could Isolate it and fix it.
dan
http://picasaweb.google.com/dan.maltby/BackFromRebuild#5388709149769213666
82 xls Roadster/Andrews PB+ Cams/S&S Super E / drag pipes/ 2"baffles/exhaust wrap
None are more hopelessly enslaved than those who falsely believe they are free!
Old 18th June 2009
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Other Motorcycle Year: 1969
It's probably that Valvoline oil you bought....
Seriously though, could it be a slight pinging, like when you get on the throttle or are lugging the engine? Ironheads will do it a little when hot, especially if the timing's a little advanced, you're using low octane gas, and/or it's running a little lean.
Old 18th June 2009
jpironhead jpironhead is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1979
jpironhead is on a distinguished roadjpironhead is on a distinguished road
try high octane fuel.
Old 18th June 2009
Chris B.'s Avatar
Chris B. Chris B. is offline
Sportster/Buell Model: Ironhead 1000
Sportster/Buell Year: 1973
Chris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura aboutChris B. has a spectacular aura about
+1 to that, run some higher octane racing fuel through it. 110 or equivelant. Then, steady off yourself with around a 95-97 octane mix. Thats what works for me anyways... That might help with any pinging like 83XLX mentioned. If you cannot get racing gas locally, just buy some booster and do the math on how much to use, I use about two cap fulls for the stock tank, and I also have to mix the lead substitute in there. There is a lot of "do I need lead?" threads and yes, you do if the bike orginally called for it. It really helps seal the valves to the valve seats for good performance and compression. If you don't wan't to run leaded, and the bike called for it (unsure on the 82) then you'll need a newer head and valves that are made for unleaded...
I've read that top ends can be noisy, over time it might need a re-adjust but try the gas first.
Chris B. -'73 Ironhead
Old 19th June 2009
runingmouse's Avatar
runingmouse runingmouse is offline
Sportster/Buell Model: xlx
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1979
Other Motorcycle Model: Sprint ss
Other Motorcycle Year: 1967
runingmouse is on a distinguished roadruningmouse is on a distinguished roadruningmouse is on a distinguished roadruningmouse is on a distinguished road
I thought I had the same noise once.....bad fuel cap.....and later loose bolt on tank.
Old 19th June 2009
xlcruser's Avatar
xlcruser xlcruser is offline
xlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the rough
Same here, loose tank bolt, the washer was tinkling like a lil bell. About drove me nuts.
I didn't buy a Sportster because I wanted a Harley, I bought a Sportster because it's OLD S'COOL
Old 19th June 2009
Paul2281's Avatar
Paul2281 Paul2281 is offline
Sportster/Buell Model: 1984 Sportster
Sportster/Buell Year: 1984
Other Motorcycle Model: 2002 Kawasaki ZX12R
Other Motorcycle Year: 02
Paul2281 will become famous soon enoughPaul2281 will become famous soon enoughPaul2281 will become famous soon enoughPaul2281 will become famous soon enoughPaul2281 will become famous soon enoughPaul2281 will become famous soon enough
I have a 84 and I run the 93 octane AND I use Lucas Motorcycle oil 20w50 with 1/2 qrt. of Lucas oil additive...My motor runs alot quieter than before the oil change up....JMO...
IF YOUR NOT LIVING ON THE EDGE, YOU`RE TAKING UP TOO MUCH SPACE....
Old 23rd June 2009
mandaltby's Avatar
Default engine noise
Im trying to figure out what it is. I dont see a loose bolt, it looks like its coming from engine area. It does it at lower idle speeds, the sound of a key hitting at the bottom of a cooking pot. Or a knuckle at the bottom of a pasta sauce pan. The bike is an 82 and was always noisy, IM just hoping that nothing is wrong, I hope to make till winter and a time for a rebuild. IU put in lucas plus the higher octane, engine has tons of power, however the noise still there.
Old 23rd June 2009
Hard to say without hearing it, but the description sounds like a rod starting to knock.
Old 23rd June 2009
Campsurf Campsurf is offline
Sportster/Buell Year: 1970
Other Motorcycle Model: Triumphs
Other Motorcycle Year: 1964
Campsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the roughCampsurf is a jewel in the rough
Get an opinion from a local shop or another "knowledgeable" rider... if I can't hear it with a full helmet on .. I don't worry about it !!
The only ticking I can think of is the valve train .. is in the top end? Then I suspect it is in the rockers.. have they ever been rebuilt? About how many miles are on them? Check your push rods and timing again.
Jim
I am curious about the Lucas 20w/50 oil... I have never heard of it or seen it.
