Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Sky Smith Insurance
Lickscycles
CV Performance
Ricor Shocks
Old 20th June 2005
mailmanjohn's Avatar
mailmanjohn mailmanjohn is offline
Sportster/Buell Model: sporty
Sportster/Buell Year: 02
mailmanjohn has disabled reputation
200 horse and turbo + the heat of street riding on a sporty. would not be a good mix......but for sure could be done.
Old 20th June 2005
wickedsprint wickedsprint is offline
Sportster/Buell Model: zx-10R
wickedsprint has disabled reputation
Originally Posted by Jeffytune
I think turbo would be cheaper, and have more reliable power, plus you cannot beat that sound of a turbo spooling.
The sound of a Supercharger winning, no lag.[/QUOTE]
Up for debate, if you have turbo lag you are not driving it right ~Carroll Shelby
...turbo also is better for the engine and more likely to get his power numbers since just using waste exhaust, a supercharger is wasting energy and putting alot more stress on the crank, but it is the easy way out.
Old 20th June 2005
Turbo is only silly hot when you are flogging the hell out of it, there is no difference between the EGTs of an exhaust pipe of a well tuned NA motor VS the EGTs of the turbo charger when both are under full throttle, they both get just as hot and a turbo stays relatively cool when driving in normal traffic. I have glowed a few turbos of mine before though
Old 20th June 2005
hell of alot of heat generated in the turbo it's self...............hot oil.........hot bearings...................short life.
Old 20th June 2005
Again not true, a well tuned engine running a turbo, the turbo will usually last the life of the engine, my turbo in my last car had 148K HARD miles on it when it gave up the ghost. Turboes can last forever if you take care of them, let them cool down, let them warm up when shutting down the bike or starting it up (respectively)
A turbo in a sporty will NOT be working hard at all. I still think a turbo would be a very viable option, and likely the most realistic, especially since you can dial the boost back and run pump gas or dial it up for even more power onr acew fuel, ona high compression motor you are stuck running race gas all the time, plus a low compression turbo motor will be making LESS heat at idle and lower power settings..IE: around town.
Have you owned or worked on any turbo vehicles? Just curious.
Old 20th June 2005
again i don't disagree with you. like you said well tuned. at 200hp your tuning becomes very important. if you think the heat generated by the now 200hp vtwin will not dramaticaly increase your wrong. so your tune up better be dead on.................one rattle and that motor will grenade. so my point is on the strip where you can control the bikes temp and tuning....GREAT. but on the street where you can't control traffic or lights and the heat of the bike. you have the potential for trouble.
Old 20th June 2005
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster!!
Sportster/Buell Year: 01
xllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant futurexllent01 has a brilliant future
Travis Lummus don't need no turbo or supercharger just plain cubic inches
and alot of riding skill to be the best in the world. Thank you ASW for
correcting me on the world record.
TRAVIS LUMMUS
Gene Lummus Harley-Davidson Racing
What makes these records special?
In this class, the motorcycle must be street legal with a registration card and,
5.5 lbs per cubic inches no slick no air shifter no wheelie bars
Additional Triumphs:
Best Appearance Team - 2000 Best Appearance Team - 2001 Best Appearance Team - 2002 2000 Wrench of the Year - Gene Lummus 2002 Wrench of the Year - Gene Lummus
Travis Lummus Sponsors:
S&S Gene Lummus Harley-Davidson Red Line Oil Spyke Starters and Transmissions Rivera Engineering
About the motorcycle:
S&S Motor built by Gene Lummus
Components: Cases/Heads/Crank Shaft
Pro Street Frameworks frame Kosman wheels and front end Kosman fuel tank Axtell cylinders J&E pistons Spike starter Works shocks Red shift cam Zippers products S&S B1 cylinder heads reworked by T-Man Performance Bandit clutch R&D transmission
82 Locust Road
Waynesville, NC 28786
OPEN Monday thru Friday: 9:00 am - 6:00 pm
Saturday: 9:00 am - 4:00 pm
TEL (828) 454-0066 FAX (828) 454-5666
2130 US 70 Highway - Swannanoa, NC 28778 (just outside East Asheville)
OPEN Monday noon - 6:00 pm, Tuesday thru Friday: 8:00 am - 7:00 pm
Saturday: 8:00 am - 4:00 pm
TEL (828) 298-1683
RTFS
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
Old 20th June 2005
SxysCowboy's Avatar
SxysCowboy SxysCowboy is offline
Other Motorcycle Model: Kawasaki 750 H2
Other Motorcycle Year: 1972
SxysCowboy has disabled reputation
i have 3 turbo drag suzukis two pushing 450hp and one promod pushing 575hp,.....absolutely JAPs have there shit together i work on them all and i ride them all. by far japs got us whupped. BUT i LOVE my harley it rides rougher rides slower and i work on it twice as much. but for some unknown reason i would not trade it for the fastest jap there is. what i wanted to do is build a custom and build it similar to a drag bike with tubular frame and aluminum fuel cells. and unless some wild thing happens i HAVE to get turbo i just love it and i see toomany drag bikes suffer on NOS and we still strut on with our turbos. the only reason i did not call NHRS first is because this is a future project and right now i do not have the dough and didn't want to waste hisa time till i ready.... also i was curious int nallins post he showed a dyno chart with over 200hp but the tourque falls fast how come? and what was done to this motor? also sorry to start such a fire with all this just curious. i think i can build and turbo the motor i want for about 15,000.
Old 20th June 2005
SxysCowboy's Avatar
while i was writing that i got the answer to my question about the bike with 212 thanks fellas but why does the tourque fall so drastically
Old 20th June 2005
HD1200R's Avatar
HD1200R HD1200R is offline
Sportster/Buell Model: XR1200x
Sportster/Buell Year #2: 1993
HD1200R is an unknown quantity at this point
1st thing I would do is start with a set of S&S cases. After that, I'd talk to NRHS and let them use the knowledge that they have to make it right the first time.
I think a Sportster's streetability ends around 150hp. Anything after that requires a LOT of upkeep. Probably frequest teardowns too.
Wy are you looking for hp if it's going to be more like a drag bike? Why don't you look for 150+ ft. lbs. of torque? HP is only necessary to carry the bike through higher speeds. Torque will get you down the track or ahead of the people you want to embarress fast enough where you won't need extreme hp numbers.
1993 Harley Sportster 1200cc
2011 Harley Sportster XR1200x
